TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: johnny on September 09, 2019, 04:05:01 PM
dielectric grease or conductive grease on brick electric connectors...
im saying conductive... what brand you use...
Loctite 8801
I use Dielectric, non-conductive. Prevents stray current from leaking, but more importantly it prevents air from getting to the metal terminals and causing corrosion/oxidation.
Depends...
Dielectric grease (silicone) is good for bulbs and large connectors to keep the elements out but dielectric is an insulator which can present problems on some connections.
When I worked at the Chevy shop we used dielectric lubricant to help prevent fretting and moisture intrusion on fine pin connectors. The only product I know of that actually enhances connectivity is Stabilant which is insanely expensive.
