TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: Rcgreaves on August 18, 2019, 10:26:01 AM
Title: Re: K75S radials- mushy in high speed corners and its not all about tires is it?
Post by: Rcgreaves on August 18, 2019, 10:26:01 AM
I may have issues...sounds like the lead in to a joke:  my 87 K75s would track hands off at any speed.  I want that with K2 or k bike #2.  I have new bearings for the triple tree but it may just be that the clamp on those bearings have loosened so that痴 where I値l start.  I could order up some of that stuff Corning grease and repack the steering damper as a matter of course...25 year痴 old, worth a look..
I struggle to imagine how my forks could be twisted or misaligned for stiction until I relive how my 87 looked after sliding on its side at 80 into a ditch- a bent fork would do this right?  point being that I have never taken them off etc who knows what a PO did to/with it so I値l break out my long straight edge and while I知 installing my low seat maybe reposition things a few mm lower.  Maybe fresh front fork oil.
Is the rear swing arm bushed  in a way that slop could be introduced at the rear swing arm through a worn bushing? Like my Water Buffalos?  I think not.  Maybe the aluminum housing could elongate and get hogged out if loose?? When I install my new T30 in a week I値l be certain to scrutinize all these pivots.  How do I trouble shoot my rear shock of unknown  age?  Maybe my rear spring preload is set too soft?? I知 a petite 210# after all. Who services rear shocks?.  I値l look up those settings today and if anything stiffen the rear.
Pouring rain Sunday morning here in the Chee, good day for service.  Maybe there痴 a paralever in my K75 future.  Cheers mates.  I greatly enjoy and appreciate the feedback here.
Post by: Rcgreaves on August 18, 2019, 10:43:15 AM
In an earlier reply marshall suggested better than stock front springs.  Ok, what from what source would be an appropriate update front spring update?  Rear damper age Marshall asks� I値l dig I may have a dated receipt.  Cheers
Title: Re: Re: K75S radials- mushy in high speed corners and its not all about tires is it?
Post by: K1300S on August 18, 2019, 08:54:35 PM
front springs...
-Progressive brand popular, but they are one rate fits all.  i had them.  unimpressed.  ditched them for...
-Race tech, much better.  you get a spring rate that is "fitted" to your usage and weight.  not everyone is the same. https://www.racetech.com/ProductSearch/2/BMW/K75%20C-S-RT/1992-95
#210 is heavy for a stock rear spring when it was new.  30 years later the spring is softer than it was, and guaranteed the damper is shot.  rebuilding waste of time.  just get a new one.  can't go wrong with Ted's https://www.beemershop.com/  there are a range of options.
I have
K75S #1  progressive front/ progressive 465 rear.  works ok on track.  that is all this bike gets used for.
K75S #2  Race Tech front/ Fox DA rear.  works great on track or street
K1100RS  Race Tech front/ Progressive 465 rear.  has not been on track, but very happy with sport touring riding
K1300S    Wilbers DA front and rear with ESA function deleted.  freaking awesome control...track or street.
A good suspension makes a HUGE difference in how a bike rides and handles.  It is not a place to ignore or cheap out if a bike is to be enjoyed.
Post by: Rcgreaves on August 21, 2019, 02:01:50 PM
Turns out my rear shock is a Wilber痴 with 46 46 50 220 spring installed.  Nice Geeeerman unit..
The tech at Beemer bone yard says that痴 a spring for a 300# load.  So for one up riding that痴 a bit stiffer than optimal and two up I would want to dial in some preload.
The 50 translates to 286# to compress one inch.  I weigh 203#
So my plan for the rear is to set sag to 1 1/4� and off the damping dial all the way 25 clicks counter- clockwise and see how she feels at different settings.  Maybe low mid high..
Wilber痴 suggests rebuild every 12k miles - age unknown-  maybe I値l have them look it over this winter. A softer rate spring could impact my wobbles.  Cheers.
Post by: K1300S on August 21, 2019, 02:04:33 PM
good stuff for the rear.   you can get a lighter spring for it if needed.
check your front springs too.  the front shock oil weight can also be changed to affect damping.  when was it last changed?
Post by: stokester on August 21, 2019, 04:35:42 PM
front springs...
I've got Race Tech in my '93 which were installed by the original owner so I don't have a good comparison but during an Airhead Tech session with Tom Cutter at the MOA National Rally he did not have kind words for the Progressive fork springs.  I know this was regarding Airheads but he left me believing they made a basic fork spring and sold it for many motorcycles without regard for its ride characteristics.
The '94 will probably get a set of Race Techs this next year as well as a YSS rear from Ted.
Post by: Rcgreaves on August 22, 2019, 07:35:01 AM
So with the threaded washers dialed all the way back I got the 1 1/4 inch sag recommended when I add my body weight.. ( it took me ten days to realize that the top locking rings need to be dialed down to match the weighed top position of the spring... Washer rattled for 100 miles til I inspected everything again. Dopf.
 A bonus is both feet now touch solidly where til now my 29� inseam has been a 鍍apping act�. I have yet to install my OEM low seat.  I知 liking this!   9/24 low seat and strut adjust yielded flat-footing, very pleased.
So dialed all the way off - (counter-clockwise 25 clicks) on the damping wheel bottom of strut cartridge -crossing a bridge bump gives two noticeable rebound bounces. My butt says one on same bridge is a suitable benchmark.  Cornering and wobble characteristics are the same.  BBoneyard tech suggested 28 and 30 pressures for solo so I値l soften tire pressures to that for today痴 commute.
Overnight I spent time really standing on the front binders; I知 satisfied with the damping/ weight transfer etc.  I知 really hoping fresh bearings-races in the triple tree and fresh damper grease will yield some noticeable reduction in cornering wobble.  9/24/19 - Dyna beads came out with tire change and none of this proved necessary. I'll save those service steps for winter R+R time
August Is just so 土ee Haa� as Johnny says I think I値l await snow fall before I lay up this bike.  I spose 400 miles a week commuting isn稚 great for whatever is causing this shake, this is no museum piece right?  I was praying that change in rear geometry might help.  No joy.  As always guys I appreciate and value your replies.  9/24 - after rattling the crap out of the triple tree and front wheel bearings I'll renew both over winter...Cheers.
Post by: The Mighty Gryphon on August 22, 2019, 12:11:00 PM
Sounds a bit low.  Scary, squirmy low.  Factory spec and general consensus is 36-38 front, 40-42 rear.
Post by: Filmcamera on August 22, 2019, 01:48:11 PM
28 - 30 is fine if you are going to be doing track riding on it but for street you are unlikely to get it warm enough to expand enough for those pressures to be ok.
Post by: K1300S on August 22, 2019, 02:38:20 PM
agree with both of the above.  those pressures way low and will contribute even worse handling.
Post by: stokester on August 22, 2019, 06:46:49 PM
Yup, I usually run 37 and 40.
Post by: The Mighty Gryphon on August 22, 2019, 07:37:33 PM
I wonder if those tire pressure recommendations is how Beemer Boneyard gets their parts bikes.
Post by: Rcgreaves on September 24, 2019, 11:49:49 PM
So this thread is done.  Lots of lessons learned:
Radials are a plus
Dyna Beads are not as reliable as conventional wheel weights.
Don't stop troubleshooting when plan A yields nothing, the pay off is worth the hunt.
