TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JPaganel on August 17, 2019, 12:55:12 AM
I had another go at fixing my speedometer. Deoxit on all connectors, cleaned what I could reach. Results are underwhelming. I actually made it worse. Still no speed, now my clock is wonky. One of the backlight bulbs comes and goes.
Kinda thinking of maybe replacing the thing with a new gauge cluster.
I read the threads about the electronic needs, like BEP, or RBM's boards. Not worried about that.
Wondering what people use for dashboards. I'm not really feeling the wildly assymetric ones. Oldschool looking round ones... Meh. Doesn't really do it for me either. A digital one is a maybe.
What style might look decent on a naked K? What is a good mounting option? Which ones aren't annoying to look at? Green backlight, or one that could be changed to green, is a plus. I like OEM green lights.
I think the Brick got wind of this thread. Speedometer kinda started working today...
Maybe the DeoxIT has dried and current is completing the cleaning task. Please define kinda working.
DeoxIT needs time to work and requires a flush with another shot of the cleaner to be effective.
I had a random working GPI so I pulled the pod out and used Deoxit on the instrument plug. This worked for a while but the intermittent GPI indication returned but not as bad. So I pulled the pod again and used a pointy Exacto blade to carefully scrape the pins. I then used CRC cleaner lubricant (I'd run out of DeoxIT) to spray the contacts. So far the GPI has been working with no problems.
Well, today it worked perfect for about 8 miles. And then didn't work at all for 10.
So, it comes and goes at will.
I've been through a few bread boxes in my bricking career.
In that time, thanks to the de-loopers and de-hoopers, used bread boxes have gotten a lot cheaper and more plentiful.
My advice is, get a new one off a forum buddy or Ebay. Make sure it's the newer type, with the two circular one-way vents in the back. Chances are it will work fine.
If the new one has one or the other thing that doesn't work, with a couple of bread boxes in your inventory you can swap various bits back and forth until you have one that does it all.
