TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: GaryFrank on August 03, 2019, 03:58:58 PM
Has anyone fitted a hydraulic clutch to the K100?
I need to replace the right handlebar switch on my K100 and have a VFR800 that I can use as a parts doner.
The VFR has a hydraulic clutch....
i suspect replacing switch with correct k-bike one will be A LOT EASIER AND CHEAPER than trying to kludge on a complete master, slave and reservoir hydraulic clutch system from a completely different bike.
and you mean LEFT switch? not sure how the right switch is related to the clutch..
Hahaha.... no, right switch is toast, left switch is 💯 but it will look kinda stupid if I only replace the right one .....that’s where the Hydraulic clutch bit comes in. VFR800 has what I need (and is free) but has a hydraulic clutch.
So......K100 scrambler with a Honda switches & hydraulic clutch ch 👍👍👍
I've never heard of anyone trying it, probably need some creative fabrication for the slave cylinder. Not sure if the difference between a multi-plate wet clutch and a single plate dry clutch would enter into the equation.
+1 As per Chaos you would need to work out where to mount the slave cylinder and also calculate the correct throw distance (travel).
