TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: billday on July 22, 2019, 06:07:20 PM
Title: How far will a tank take you?
Post by: billday on July 22, 2019, 06:07:20 PM
Somewhere recently I said how I always gas up around 150 miles.
On Friday I proved to myself that I can go 180 on a tank. I didn't set out to make this point, it was exciting going deeper and deeper into the Adirondacks not knowing when I'd see fuel again . . . took just a hair over 4 gallons.
* IMG_4790.jpg (69.13 kB . 768x576 - viewed 831 times)
* IMG_4791.jpg (38.26 kB . 432x576 - viewed 788 times)
Title: Re: How far will a tank take you?
Post by: caveman on July 22, 2019, 06:52:27 PM
I"m looking for gas around 120 miles on my RT or LT if riding hard and can get 180 or a bit more if taking it easy. If I push those big fairings over 80/ 85 MPH it seems like all I do is go gas station to gas station! On the 75S I get 200+ most all the time unless pushing very hard.
Post by: The Mighty Gryphon on July 22, 2019, 07:48:35 PM
BillDay, looks like you are getting the standard U.S. 45mpg with your brick.  I have 60,000+ miles of experience with 4 of the beasts so far, and unless I am hammering my bike at 85 into a headwind I get a pretty consistent 45-48 mpg.
As for the farthest I've ever gone, it was across Wyoming through a 95 mile stretch of nothing taking a "shortcut" to get to Rawlins for the night.  When I finally got to a gas station, I had about 230 miles on my tripmeter.  My RT took a hair over 5 gallons.  For the last 20 miles the fuel pump was screaming in agony.  The pucker factor was pretty high that evening.
I commute 108 miles round trip to work and back.  I fill the tank approximately every other day, at around 190 to 205 miles.  I've been doing that with four different bikes for about 5 years and not had a problem.  I know I can go further, but the low fuel light can be annoying at night.  It comes on with my bikes about 188-190 miles when there is still a bit more than 1 gallon of fuel left in the tank.
Post by: stokester on July 22, 2019, 08:47:09 PM
///CUT///
That's pretty much my experience as well but that fuel lamp staring at me starting between 130 to 150 miles depending on my city/highway riding is always an irritant.  I still like my airheads petcocks where I know how much is left when I switch to reserve.
Post by: The Mighty Gryphon on July 22, 2019, 09:08:35 PM
it seems odd that the lamp comes on with nearly 2 gallons(40% of tank capacity) remaining.  The spec for the tank is that the warning light comes on with 5 liters remaining in the tank.  There is an adjustment for when the lamp is triggered.  It may be misadjusted.
Our friend RBM has posted some good information on this topic.
http://www.k100-forum.com/t9265-messing-with-the-in-tank-fuel-sender
Post by: Past-my-Prime on July 22, 2019, 09:25:29 PM
Fuel light comes on at 280 or so kilometers. 170 miles
I ran out once at about 360 kilometers. 220 miles
refill always by 330 by the Odometer - 200 miles but usually 290 partly to keep my fuel pump cool and partly because I dislike the red light.
Take usually about 17 liters if I go that far.
so 5 l/ 100 km = just under 50 mpg and I do not drive slowly. Big fairing RT on a K75.
Post by: Martin on July 22, 2019, 10:08:10 PM
If I drive like an absolute Nana I got 400 Km's out of my 75. I only did it once to see what I could get out of a tank and that was 20 years ago. I think under normal riding I think it's around 350 Km's.
Post by: cycle on July 25, 2019, 07:03:53 PM
On my 87 K100lt the fuel light comes on at around 175 miles. On my 90 K75rt the light comes on at 200 miles. Both bikes take 4 gallons, + or - a tenth or two, so that leaves a little over one gallon for reserve. I do seem to ride the 1000 a little more briskly than the 750. It has a noticeable difference in power and acceleration. I kind of like that :riding:
Post by: SinNH on July 27, 2019, 06:37:46 AM
On  my '93 LT:
Light on at about 145 miles
Run dry at 212
when needle just touches the red blocks, about 1 gallon left.
I keep in  mind that after the light first comes on, I got about 50 miles left
Post by: Scott on July 27, 2019, 08:29:28 AM
My light came on at 165 miles last fill, took 4.4 US gallons to fill, so I guess that leaves about a gallon (i think) in reserve. This last tank got about 48 mpg, so that would calculate to about 213 miles until completely empty. chunk.
Post by: johnny on July 27, 2019, 10:27:52 AM
running low on a consistant basis causes unecessary fuel pump whackness...
Post by: BlitzenGruv on August 01, 2019, 01:44:45 AM
The first time I rode from Nashville to Barber near Birmingham the light came on after about 150 miles. It took a bit more than 3 gal. to fill up. That was all interstate at about 75-80 mph.
It used to scare me that the fuel light came on when the gauge said I still had a 1/4 tank. I didn't know which to believe. Gives me about 50 miles to find fuel. I guess BMW doesn't want you to strain the fuel pump.
I'm going camping about 150 miles from here this weekend. Mostly back roads, it'll be interesting to see what kind of mileage I get on that trip.
Post by: Soggz on August 01, 2019, 03:10:15 AM
Just out of interest... how much does it cost for you yanks to fill the fuel tank?
Post by: The Mighty Gryphon on August 01, 2019, 06:40:35 AM
In the Fascist Republic of New York I usually fill with 4.3-4.5 U.S. gallons.  This summer that costs around $12.80 to $13.00.
Post by: billday on August 01, 2019, 08:05:55 AM
Kids, listen to Uncle J O. The fuel pump is both cooled and lubricated by the gasoline it's immersed in.
Post by: koapono on August 01, 2019, 10:30:40 AM
I get about 225 miles per tank give or take a few depending on speed/RPMs.
I seldom go more than 150 - 175 before topping-off because as JO said: imminent full pump whack.
here in Virginny fuel is 2.40 USD per gallon (3.8 L)
Post by: Laitch on August 01, 2019, 10:48:14 AM
Following this modification—if possible—will give a little more distance or a greater margin from pump whack.
Post by: Soggz on August 01, 2019, 12:31:24 PM
Wow! Is that all? It’s almost £25.00, here! No wonder the planets forked!
Post by: Scott on August 01, 2019, 12:45:49 PM
Currently here in Southern Ca, to put 5.5 gallons in, it would be about $22.50 US at today prices for premium.  They don't give it away here either.  And we get that ethanol shit as a bonus.
Post by: Soggz on August 01, 2019, 12:54:59 PM
Thats only about £16.00.
Post by: alabrew on August 01, 2019, 01:33:17 PM
My son (he has a r1100s) and I are experimenting with different fuels. He swears that he gets his best mpg on shell. I really hadn't paid much attention, and I normally go with chevron if I can, but I filled at the shell the last tank and today hit 195 miles with no fuel light. Filled and only put in 4 gal. (at $3.05 for premium). I typically only get about 180 until the light comes on with the chevron and I add 4.2 gal.
Post by: BlitzenGruv on August 01, 2019, 08:42:09 PM
I use mid-grade fuel with no problems. That's about $2.80 here in the South.
Some of the local stations offer pure petrol, but only in regular grade. I'm tempted to see if the K will tolerate that well.
Maybe they could add a warning light for the knock sensor?
Post by: alabrew on August 02, 2019, 04:18:08 PM
No knock sensor, that is why I run premium, especially in the summer.
I ran regular in everything up until I got the '05 KLT and another board convinced me that it wasn't too much more to run premium.
The '02 KLT started much better in the winter with regular.
Post by: natalena on August 02, 2019, 08:30:06 PM
Currently, it's about $2.26/gal here in Maryland, so a regular 200mi fill-up is close to $9.00.
When we lived in Italy, it converted around 8-$9.00/gal. and the attendants would stop pumping at 130 euro, as I encouraged them "pieno, pieno!" to top off the truck. The NATO coupons offset the costs, so we didn't care.
Egypt was .28 cents/gal, and nobody cared about how much fuel the 4x4 burned.
Post by: daveson on August 02, 2019, 09:36:03 PM
I try to fill up before the needle goes under the quarter full mark, about 150 miles, which is also when the warning light comes on. I use 91 octane.
Post by: billday on August 03, 2019, 05:54:47 PM
Our motors run fine on regular octane gas, and I think they really appreciate an ethanol free diet. If I could get that where I live, that's all I'd give my K.
Post by: Martin on August 03, 2019, 06:32:05 PM
When I first got my Brick I was told to replace the fuel pump damper and hoses as they could be turning to Vegemite. I bought a damper as a precaution and when pulling it I found no deterioration but replaced it anyway. It now resides as an unneeded so far backup. A mates four bricks all had  damper meltdowns and pump failures. I still have my original cleaned and stored and working pump even though I'm now running a Chinese pump as an ongoing experiment. The only difference between my Brick which has higher K's is that it has never run on ethanol fuel, and his have until I warned him, but the damage had already been done mainly by previous owners. Mine has also never been allowed to sit and is used at least 3-4 times a week.
Post by: John Lang on August 03, 2019, 08:36:12 PM
I filled up with regular (85 octane) and have noticed no complaint from the engine. I just replaced my fuel pump damper and mesh filter for ones said to be ethanol resistant. (www.tills.de). Regular is $0.25 per liter cheaper than super so a saving of $5 per tank-up would quickly pay for the replacement parts. I may do this. Heresy, I know. The original damper was a bit deteriorated after 160,000 km; the old mesh was fine. The bike has always used only ethanol-free gas.
I also bought new fuel hoses to replace the originals. The old hoses still look fine but as I have new ones I'll put them on.
The tank took 18.1 liters after travelling 392 km. That's 21.6 km per liter. So the remaining 2.9 liters in the tank would have taken me another 63 km, a total of 455 km or 284 miles -- assuming all of the tank's contents is usable and I don't turn or accelerate when there is only a liter or two remaining.
Post by: The Mighty Gryphon on August 03, 2019, 08:56:55 PM
The main reason for high octane premium fuel is to prevent pre-ignition when large throttle openings are used.  I drive fairly sedately but briskly, almost never using more than half throttle.
My engines run very happily on 87 octane.  The only reason I use the premium 91 octane stuff is to avoid leaving my bikes sitting for extended periods(over the winter) with ethanol in the tank.  That is a recipe for disaster.
Post by: daveson on August 03, 2019, 09:27:10 PM
Down here the options are 91, 95 or 98 octane.
Premium, 98 is the most expensive. I use 91 because I go cheap. Can't even get ethanol blend  (10%) unless I go to the next town.
I have a vague memory that the calculations might be done a bit different in the USA.
Post by: John Lang on August 04, 2019, 11:59:17 AM
Chris Harris has a new video showing what happens when you store a bike with corn ethanol in the tank.
https://youtu.be/WXpf-AC-uvw
Post by: Scott on August 04, 2019, 12:28:27 PM
Yeah, i saw that too, and in their infinite wisdom, Washington DC is mulling over allowing even more ethanol in the US fuel supply.  Thank you special interests, and thank you also to the "corn" senators that reside in their pocket.  scott.
