TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jjconeill on July 11, 2019, 05:22:32 PM
Title: no power to ignition
Post by: jjconeill on July 11, 2019, 05:22:32 PM
thanks all good information, 1987 K75 while showing my bike for sale the ignition light and power became intermittent, lights go out, and if on the start button will break the circuit, tried rebuilding ignition switch but broke it, replaced with new but same thing, even worse now that the new switch is connected. no power to ignition. Help!!!!
Title: Re: no power to ignition
Post by: jjconeill on July 15, 2019, 05:12:04 PM
I'm not great with mechanical things or electrical for sure, but guessing if I jumped two wires on the ignition switch connector under the gas tank that would prove the problem is not from the connector to the key switch that I just replaced, yes. anyone know what color wires to test?
Post by: Scott_ on July 15, 2019, 06:38:03 PM
Red is the supply battery power.
Green is the wire to the r.h. kill switch(then fuse #1), load shed relay coil, and other components related to the ignition system.
Grey goes to fuse #2 then to BMU,
Grey/Blue is for headlight, park lighting.
When the switch is in the "P" position, Red is connected to Grey for park lighing.
When the switch is then in the "I" position Red is connected to Green, and Grey is connected to Grey/Blue.
Post by: jjconeill on July 16, 2019, 03:22:14 PM
Thanks Scott,
Post by: alabrew on July 16, 2019, 05:38:01 PM
I have a (hidden) flip switch instead of the keyed ignition switch on the "91. It too is on the "To Do" list once I have it all undressed next time.
Post by: jjconeill on July 23, 2019, 04:37:13 PM
So I replaced my ignition switch with a new one, in on position for lights, nothing, in I position I get lights only, no ignition. tested for twelve volts from red to other three wires 12v every where, bad switch? I'm going out to jump switch!
