TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zipster68 on July 12, 2019, 12:36:46 PM
Hi,
I've got a little clutch slippage when I fully gas it in 4th and 5th. Tiny bit of oil from the weep hole. I'm facing a 1200 mile Lake Michigan loop this August. Should I risk it? No shudder during takeoff, clutch is freshly adjusted. Only seems to slip when hot.
Also, from the photos.....do I have a RS or RT or fairing strapped to a stock K100?
cheers,
Ray
Sounds like a clutch o-ring leak. The fairing looks like a cut down RT fairing on a C or s model. I like it.
Put your moto's VIN in a VIN-decoder (https://www.realoem.com/bmw/select.do?kind=M&arch=1); all will be revealed. The fuel tank cap is 180º out of position. That can allow moisture to infiltrate the tank more easily.
Look for the rubber bushing indicated in the diagram where the front of the engine is mounted to the frame. If it is absent, your moto is likely a naked K100 that has been modified with an RS upper as TMG has indicated. There were no K100S or C models. If it is present, it's a cut-down RS fairing on an RS frame with additional naked K100 radiator shroud parts.
(http://www.motobrick.com/gallery/2/1601-120719155836.png)
Contact by the clutch arm bolt should be just touching; I measure freeplay at the lever while using light pressure with just one finger on the lever. Sometimes a slight readjustment is all you need.
I'd risk it regardless. It's not mountainous. Just don't goose the engine. Fix it if you're risk-averse but it's a slippery slope—clutch disc replacement, o-ring, maybe a new compression ring, maybe new clutch pack nuts, maybe a new rear seal, how about the clutch rod boot, a new rod seal, maybe . . .(http://www.motobrick.com/data:image/gif;base64,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)(http://www.motobrick.com/data:image/gif;base64,R0lGODlhHwAWAPUGAP/iHPraEP/eGEA0EP/mIP/aFKrq/zzK9vbKAP////rWDFVACO6qAG1MBJlxBPLCAPK2AP887sIAsvK+AFlACOadAO6yAM6JAKVxBKVpAPrSBMKJAK6BAHFQBPbGAPrOBPLGAM6lANquALKNAK6JBKF5BN62AOqhAO66AOalAO6uAOKVAJVlBK55AN6VAEAUEPLOGF3W///mOP8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEAAAAh/h1CdWlsdCB3aXRoIEdJRiBNb3ZpZSBHZWFyIDQuMAAh/iFEZXNpZ24gYnkgQWl3YW4gKGFpd2FuQHlhbmRleC5ydSkAIfkEBTIABgAsAAAAAB8AFgAABtNAg3BILBqPSOFiyUw6iYsOSeTxhDidxTO5KH0UgYBCg0A5tNsiJaQoDN5vBWKyoaSHi5FCMEgk+n8ICBAYaGkdH3x+f4sDCg8MDXd5CoBwb34DCBaFaQsmAZaXmYMXhk4LIKGZo4EQLqdcIJWLjI2bsJ4iGnxwBJePDKaeHAgBAAAEysoAAXMnGbFJHRPGAskEANcCEwwVkpMc1RphAmJzKhXRd0IUGxAPCJfdFS127EoOKRYQEBYMJ1awkDapAYYLFSpcyNCAID4mTfBJnEixYsUgACH5BAUUAAYALAQABAAMAAgAAAMjaCoAIioaQFoN0lJSi9IVRwSYJYqBt51cABlDPHByzLCcZyQAIfkEBTIAAAAsBAAEAAwACAAABB8QyEGpvGCkpDnu3OZlW0WVSGeqaWmWkhiKA5JVtwVEACH5BAUKAAAALAUACgAJAAEAAAMEaGqwlgAh+QQFBQAGACwEAAQADAAIAAADI2gqACIqGkBaDdJSUovSFUcEmCWKgbedXAAZQzxwcsywnGckACH5BAUFAAAALAQABAAMAAgAAAQhEMhBqbxgpKQ57tzmZVtFlUhnqmlplpIhG8NMI1mVW0AEACH5BAUFAAYALAQABAAMAAgAAAMjaCoAIioaQFoN0lJSi9IVRwSYJYqBt51cABlDPHByzLCcZyQAIfkEBQUAAAAsBAAEAAwACAAABCEQyEGpvGCkpDnu3OZlW0WVSGeqaWmWkiEbw0wjWZVbQAQAIfkEBQUABgAsBAAEAAwACAAAAyNoKgAiKhpAWg3SUlKL0hVHBJglioG3nVwAGUM8cHLMsJxnJAAh+QQFBQAAACwEAAQADAAIAAAEIRDIQam8YKSkOe7c5mVbRZVIZ6ppaZaSIRvDTCNZlVtABAAh+QQFBQAGACwEAAQADAAIAAADI2gqACIqGkBaDdJSUovSFUcEmCWKgbedXAAZQzxwcsywnGckACH5BAUFAAAALAQABAAMAAgAAAQhEMhBqbxgpKQ57tzmZVtFlUhnqmlplpIhG8NMI1mVW0AEACH5BAUFAAYALAQABAAMAAgAAAMjaCoAIioaQFoN0lJSi9IVRwSYJYqBt51cABlDPHByzLCcZyQAIfkEBTIAAAAsBAAEAAwADAAABjZAgHBAJAqPgEEioWQim8ylM7ksEquIplWbNRi23oEwdigPyofYAJEsto3IuHw+t9YR+IdYGAQAIfkEBQoAAAAsBQAIAAkABgAAAw5oB8xnqjlJwavW4LNqAgAh+QQFCgAIACwEAAQADAALAAAELxBJAYAQMiNAag+axxFdIYkdSQSgp6qBCQz0QNZZOpJCMFAvmGZIRBiKmcMBiYgAACH5BAUKAAMALAUADAACAAUAAAMGKBBy5uckACH5BAUKAAAALAUADgACAAUAAAUJIKJAz2GYxxECACH5BAkKAAAALAUAEAACAAUAAAQH0LHVjrHnRAAh+QQFCgABACwFAAoACwAJAAAGIcCAcCg8GIhII5J4OBABxMKS+JguHQzVlLJoWIncBYUYBAAh+QQFCgAFACwEAAgADAAHAAAEHBCMOQihA1XLbRADUIzkKARIqa6soWLAcZTYREYAIfkEBQoACQAsBAAIAAwACAAABCIQAEIrCQWBwQftAzIkZGmOphkoaZqlEyCQhgoiR92Wx5FEACH5BAUKAAkALAQACAAMAAoAAAYrQMBgOCAQiANE0cg0BgQDQGJKrSKq2Kw2iwQUJlXkcKLaUg3mxAFtPhwSQQAh+QQJCgAJACwEAAgADAANAAAGMkAAgEAsEgIFBGDAHBCbA8QgQa1ap9asdpsdAgTbABTBtTIq5cSKlW4s0gcDXF4+HBJBACH5BAUKAAkALAMACAANAAsAAAZjwABgQBwQCMUBIjA4GI5QQkAwUACcBEBUEEAoBIdD9FhQPJYAbRTQnUyWgmERUJgwEm9FkjhRVSgbEA9KCAiDDBUtCQsOKRYQEBYMJyssCwmLDRgXFRUXGQ2XmJgLCxSloglBACH5BAUKAAkALAQACAAMAAcAAAQhEABCKwkFgcEH7QPiAUlploMwnWxyGO35TpLAHkcAImYEACH5BAkKAAMALAUADAAOAAYAAAUZoAAMZGmSgXCupMGeh/sOkXQccy3Ng+QPIQAh+QQJCgAJACwDAAkAFwANAAAGgsCEcEgsCgdIo9I4IDgHQs0yESgyCJIBAyoUAJxgQAExOWUWEkIky6V6vwBvYcKoNCLrwZqIUASQSAgPKhVneGt7QxAPAwiOjHUtFAkSeJUSRAcGFhAQFgwnKywLQpWImEOaGBcVFRcZDaSlh5apBwu4S6aHqFNFu7y+v7S1wkPAlkEAIfkECQoACQAsAwAIABwADgAABrTAhHBILA4HSGMiAEAiCQTnAAFxLRIDaFRSVGQBBLBWEBhYrAMGISJhsIkagVgLDSgejMsiLYmwB29CCAFydGEFCBMnGQsMA31+fVxCE4NyYAByBRMMFQ1YWZCSQxyVCmVOCA8qFYxHooEJFBsQD1MIqmkVLRRFkH6xCw4MKhAQFgwnKyxXvsCRRAsNGBcVFRcZDc3Oz7EHBgsUC+PbRr/AkwnfSuzn0EIHB+zt3bHz8xK/+UEAIfkECQoABgAsAwAIABwACwAABqnAAABAKBoJgQICclkYXlCDdCoVDq6DInawdDlfsBeVqsgSiUZBYGBxQcHisVQjQB+RigcDKpNI5FMIAXV3AEoTJy8EERFvgBOCdWd1BRMMKy8SETCcYn5UHJAKa1gIDyoVGZqNb6uafhQbEA9cCKYDDBUtFK4SYYzAjAYLDgwqEBAWDCcrLE6rEa9+wRFSCw0YFxUVFxkNTlLQ1MB/UwsUC+ngVH7t7p9BACH5BAlkAAUALAEAAQAcABIAAAa2wIJwSCwaj8ikcslkDp7PZnKQSFCtUuPVWsVmhVfoszr4BsJiMgJyebmVZ4NBPJAP1q4X7KVUDGIHgQOBBzF3bnp8SRoCYgRiCm4SEopJCAEAAASbmwABCC8REQSISROXApoEAKkCExKjMLIvk0ccpxpnUAivoqSSorC1QhQbEA93CAjIDLARk7Ki0sFDCw4pFhAQFgwnK87Pz5PTz0QLDRgXFRUXGQ0L4OTSEkcL9vdDk/r7w0EAIfkECTIABgAsAQADABwAEgAABuxAg3C4KBqHyKRSuOiQRB5PiNNZLK/M0kcRCCg0CJTDik1SQoqBeiAQrAeUMnGUBtgJBEAAgYAMyGUdHwJ3eHgABQoPDA0vjlcLdAKHeYZdCBYYLzAvkCYBdgAEbwMFBQiOm51LCyCgeKRqAo4SEqusIAqiALEDAS8REQSprCIahKOxChLCMM4vtUkLHAgBhGoz2WrMwqnczNEGHRPV128B3xLOwezBEgbT5FzWXggP3BHgte35QhQbEB7w4fMAAoMK+Pixe0fEQQoLECBYYHBiBYsFtTJqDIdkQQMMFypUuJChASA5SowcQTkkCAAh+QQJCgAGACwCAAAAGgATAAAG1kCDcLgoGofIpHLRIYk8nhCns1BahYvSRxEIKDQIiKN6RVJCioIAABAIAojJhlLGjhRrNgFAUCDCGGRXHR95ewSIBAUKDwwNZQt3fJOJBF0IFoFXCyYBbHyVBG9hF4JJCyCeiAOhAQJhErGySKgKegADubKyEb0Ru7ELIhoCoRK+yMm+EgscCJ6gx8DHyr9CHRMIeGzSud7Uv7NYHNlcAdSxurvLZhsQDx5/A8rgyxK0DgwWEBAWscno2NFqgOFChQoXMvxb1gudFSNHDPBCJq6OkmlDggAAIfkECQoABgAsAQABABwAEgAABt9Ag3C4KBqHyKRSuOiQRB5PiNNZLK/M0kcRCCg0CJTDik1SQoqCAAAQCBSIyYZSJo4UawJbH0AgIBhkZR0fawB6BIkABQoPDA1KEpKSC3d7h4eJXQgWgUiSEaESCyYBewOJqQEFfwOTk6EREgYLIKaZA7murxKxvqK0IAqZmAS9v8iiswsieJmJvbzHyLO0HAi3qdG6udPSQh0T2Iauyt2vv9ULHOJcAQK51MnVQhQbEA9+fg+gvsfeSRY4YKACAgQLDE6skDYNWMAGGC5UqHAhQwNBQ74tWUDBCMY6BoIAACH5BAkKAAYALAIAAQAaABIAAAbYQINwuCgah8ikctEhiTyeEKezUFqFi9JHEQgoNAiUo3pFUkKKggAAEAgUiMmGUsaOFGsCWx9AICAYZFcdH2sAegSJAAUKDwwNZQt3e4eHiV0IFoFXCyYBbAOJogQBBQgDEqmqSAsgn4kDsaiqqRG2EbSprQqUehK3wMG3EgsieJYEv7m/wrgGCxwIvJbKsrHMuKtCHRPSa6i2qde0w0Qc3RpdscLYwxJDFBsQD35+tcDM2O9EDikWEBAsMDhxL5xBZ6waYLhQocKFDA0WqAqmLYmRI0iWDQkCACH5BAkKAAYALAEAAQAcABIAAAbfQINwuCgah8ikUrjokEQeT4jTWSyvzNJHEQgoNAiUw4pNUkKKggAAEAgUiMmGUiaOFGsCWx9AICAYZGUdH2sAegSJAAUKDwwNShKSkgt3e4eHiV0IFoFIkhGhEgsmAXsDiakBBX8Dk5OhERIGCyCmmQO5rq8Ssb6itCAKmZgEvb/IorMLIniZib28x8iztBwIt6nRurnT0kIdE9iGrsrdr7/VCxziXAECudTJ1UIUGxAPfn4PoL7H3kkWOGCgAgIECwxOrJA2DVjABhguVKhwIUMDQUO+LVlAwQjGOgaCAAAh+QQJCgAGACwCAAEAGgASAAAG2ECDcLgoGofIpHLRIYk8nhCns1BahYvSRxEIKDQIlKN6RVJCioIAABAIFIjJhlLGjhRrAlsfQCAgGGRXHR9rAHoEiQAFCg8MDWULd3uHh4ldCBaBVwsmAWwDiaIEAQUIAxKpqkgLIJ+JA7GoqqkRthG0qa0KlHoSt8DBtxILIniWBL+5v8K4BgscCLyWyrKxzLirQh0T0muotqnXtMNEHN0aXbHC2MMSQxQbEA9+frXAzNjvRA4pFhAQLDA4cS+cQWesGmC4UKHChQwNFqgKpi2JkSNIlg0JAgAh+QQJCgAGACwBAAEAHAASAAAG30CDcLgoGofIpFK46JBEHk+I01ksr8zSRxEIKDQIlMOKTVJCioIAABAIFIjJhlImjhRrAlsfQCAgGGRlHR9rAHoEiQAFCg8MDUoSkpILd3uHh4ldCBaBSJIRoRILJgF7A4mpAQV/A5OToRESBgsgppkDua6vErG+orQgCpmYBL2/yKKzCyJ4mYm9vMfIs7QcCLep0bq509JCHRPYhq7K3a+/1Qsc4lwBArnUydVCFBsQD35+D6C+x95JFjhgoAICBAsMTqyQNg1YwAYYLlSocCFDA0FDvi1ZQMEIxjoGggAAIfkECQoABgAsAgABABoAEgAABthAg3C4KBqHyKRy0SGJPJ4Qp7NQWoWL0kcRCCg0CJSjekVSQoqCAAAQCBSIyYZSxo4UawJbH0AgIBhkVx0fawB6BIkABQoPDA1lC3d7h4eJXQgWgVcLJgFsA4miBAEFCAMSqapICyCfiQOxqKqpEbYRtKmtCpR6ErfAwbcSCyJ4lgS/ub/CuAYLHAi8lsqyscy4q0IdE9JrqLap17TDRBzdGl2xwtjDEkMUGxAPfn61wMzY70QOKRYQECwwOHEvnEFnrBpguFChwoUMDRaoCqYtiZEjSJYNCQIAIfkECQoABgAsAgABABsAEgAABthAg3C4KBqHyKTSsOiQRB5PiNNZLK/M0kcRCCg0CJTDikVSQoqCAAAQCBSIyYZSFi5GijWBvQ8gEBAYZFgdH2sAewSKAAUKDwwNSRKTk3cKfIiIil0IFoJDkxGiEgsmAWwDiqoEAQUIA5SUohESTCCnigO6sLESs7+jtpeZe77Ax6O1CyJ5mgS+vcbHtUwcCMOK0Lu60tFCHRPXa7DJ3LHA1Asc4RpdutPI1EIUGxAPf3+hv8bdSQsOKSxAgGCBwYlo0oL5a4DhQoUKFzI0GCTE2xIjR+oMCQIAIfkECWQABgAsAQABABwAEgAABuxAg3C4KBqHyKRSuOiQRB5PiNNZLK/M0kcRCCg0CJTDik1SQorCYL1WICYbSpk4UggGiQRej0BAMGRlHR93eXqGAwoPDA1zC3V7bGt5AwgWgGULJgGRkpR+Fy+iVwsgnJSefBAuLzAvpCAKe5SGfKKtr0sLIhp3bASSCqISErm6HAgBAAAEzc0AAQgvEREEt1cdE8kCzAQA3AITEtUw5S/ESgsc2hqcbG/j1bfx4+hCFBsQD5V9+wz0EspRG0hNAhEHKSxAgGCBwYkV8SLUI0ZQIpIFDTBcqFDhQoYGCyJWHGgwnZEiQ4ipXGkvCAAh+QQJCgAGACwBAAEAHgASAAAG/UCDcLgoGofIpBK56JBEHk+I01ksr8zSRxEIKDQIlMOKXVJCisJgvVYgJhtKObkYKQSDRCK/RyAgGGRzBh0feHp7iAMKDwwNgwZ1Cnxsa3oDCBaBgwsmAZSVl38XVi+mVwsgn5ehfRAupTAvqCCTiImKmS6mL7KoIhp4bASVjAymMhISWAscCAEAAATT0wABbycvBBERvFcdE88C0gQA4wITDCsvEhEw77PKdBzhGp9sbxYVGe3dvP3t5BmgsAHCA0x+DjKo0IICQAmyuEnkRsRBCgsQIFhgcGIFCyv9IgRUNjECkwYYLlSocCFDA0EhS0pcRsdIESXKcuqUFwQAIfkECQoABgAsAQABAB4AFQAABv9Ag3C4KBqHyKQSueiQRB5PiNNZLK/M0kcRCCg0CJTDil1SQorCYL1WICYbSjm5GCkEg0Qiv0cgIBhkcwYdH3h6e4gDCg8MDYMGdQp8bGt6AwgWgYMLJgGUlZd/F2RsSwsgn5ehfRAuVgMEsgMSdCCTiImKma8DDAQREgzBTCIaeGwElYwMpL4SEcEDxEILHAgBAACy3AABbycZCwy00cHUQh0T2ALbBADtAhMMFY9rBNDntUQc6xqfbN6oqCBuSDl9SShsgPAAk5+G9FrIQZLP3D4iDlJYgADBAoMTK1gIGlIx2kUiDTBcqFDhQoYGI0mas3jKSBEsJU1CwjlT584KKznR/UwioWLRIAAh+QQFCgAGACwBAAEAGQAVAAAG+kCDcLgoGofIZHLRIYk8nhCns1BaDYvSRxEIKDQIlKN6HVJCisJgvVYgJhtKGTtSCAaJBF6PQEAwZFYdH3d5eoYDCg8MDVcLdXtsa3kDCBaAVgsmAZGSlH4XgUgLIJyUnnwQLlVsRCAKe5SGfBarAwS4A0ILIhp3bASSigyhDAQSAwy6CxwIAQAAuNIAAW8nGQsSBBHIugYdE84C0QQA4wITDBUNEdwD3EQc4RqcbG8qFdjt3PBmGxAPKvUJqK6FHAntEEpY4iCFBQgQLDA4sYIFGYT8Fi5pgOFChQoXMjQIhHGfxiVGiiQpmXDOFZYtXa7cZ1LmTJrcggAAOw==)
I've learned over the years that the Airhead/Oilhead/K dry clutch gives the hint of an issue always at WFO in the higher gears, where all the HP is on tap, and almost never from a dead stop. Even with high power slippage, usually you still have some time. I go for that 2/3 day ride, just ride drag instead of point . :beer:
