TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Gr-Racing on June 19, 2019, 09:50:37 AM
Title: Lug Bolt spec?
Post by: Gr-Racing on June 19, 2019, 09:50:37 AM
hi im trying to find the Lug Bolts spec for a K75c but not having much luck I did find in the service manual the Length is 55M but no luck on the rest.
Style: Locking Lug Bolts
•Thread Pitch: ?
•Seat: Cone (Conical)
•Shank Length:  55mm
•Width 12m
thanks
Title: Re: Lug Bolt spec?
Post by: Laitch on June 19, 2019, 10:12:59 AM
Use Max BMW's parts fiche. It will tell you diameter(width), pitch and length in millimeters.
Post by: Gr-Racing on June 19, 2019, 10:50:51 AM
only found the Length 55MM in parts fiche
update
 found  width on OEM site 12M still searching for pitch
Post by: Laitch on June 19, 2019, 11:29:10 AM
update
Take another look; it's still there.
Post by: Laitch on June 19, 2019, 11:43:57 AM
From which source are you getting 55mm length for a K75 rear wheel bolt? That length differs in the parts fiche at Max and the pitch is right beside it.
Post by: mw074 on June 19, 2019, 12:51:55 PM
3 spoke wheel 36 31 2 333 226    WHEEL BOLT - M12X1,5X60  Wheel bolt, M12 x 1.5 x 60.
Cast rear rim  36 31 2 333 225    WHEEL BOLT - L=55MM  Measures M12x1.5x55mm.
Post by: Gr-Racing on June 19, 2019, 01:18:45 PM
thank you for your help.
Post by: Laitch on June 19, 2019, 01:49:50 PM
There are actually two lengths for Y-spoke bolts. Those made after 08/90 are 60mm but regardless, the fiche discloses all that at the click of a mouse.
