TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ckp on June 07, 2019, 09:01:21 PM
Title: Oil Filter Wrenches
Post by: ckp on June 07, 2019, 09:01:21 PM
The muffler clamp got it loose. Didn't work putting it on.
Title: Re: Oil Filter Wrenches
Post by: alabrew on June 08, 2019, 12:08:52 PM
Been there, done that!
I’ve better luck drilling three screws through that black one into the filter to give it some bite.
I’ve also had to lay the beast over and remove the oil pan to drill out a filter (installed by someone else)
That was on my very first oil change on the ’85 RT.
Still riding and wrenching...
Post by: The Mighty Gryphon on June 08, 2019, 12:59:26 PM
I hope there is a special place in Hell, probably right next to where the guys who use NGK plug wires go, for the A-holes who use a filter wrench to torque the damn filter down on a dry gasket AFTER they wiped the oil from the sealing surface.
My first year as a marine mechanic I did about 100 oil changes on engines that had the filters torqued by the previous guy.
