MOTOBRICK MARKETPLACE => NM ~ Not Mine - Just Compeled To Post It Up => Topic started by: volador on June 05, 2019, 07:36:26 PM
Title: BMW K1100RS YSS Damper
Post by: volador on June 05, 2019, 07:36:26 PM
Looky here, after all this malarkey of dampers, YSS and bins
Soggz you need a K1100rs! Check your spring rate
Ebay BMW K1100RS YSS Damper (https://www.ebay.com/itm/BMW-K1100RS-YSS-rear-mono-shock-absorber-NEW/133075421055?hash=item1efbe9c77f:g:hMMAAOSw4mpc9CZ3)
Looks like the right size box
Title: Re: BMW K1100RS YSS Damper
Post by: Martin on June 05, 2019, 09:21:09 PM
The K1100 has a longer shock absorber than the K75.
Post by: Soggz on June 06, 2019, 02:06:44 PM
mines shorter. 35cm.
Post by: volador on June 06, 2019, 02:23:58 PM
Stock OEM Damper length
K75, K100 (monolever)- 360mm
K100 4V, K1100- 390mm
Post by: Soggz on June 06, 2019, 04:45:17 PM
are they measured from end to end, or from the top and bottom hole centres?
Post by: volador on June 06, 2019, 05:04:39 PM
Measured center hole to center hole
Those are general values
Your damper length is your preference
Post by: Soggz on June 06, 2019, 06:05:06 PM
Ok, thank you.
