TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Skunky on June 04, 2019, 11:07:07 PM
Title: To Start or not to start. That is the Question
Post by: Skunky on June 04, 2019, 11:07:07 PM
Morning Brickers
I have a question with regard to a starting issue.
I keep my bike on a trickle charger. When I start her she starts and runs fine. When I stop and go to start again the starter does not turn. I also lose my lights indicators horn etc.
I tried the reverse sprag thingy and it sometimes helps.
If I leave it on the trickle charger for a while it will start again. I'm not sure whether the issue is with the starter or alternator. The Battery light goes off when the engine starts.
I understand that the Load Shed Relay will take the power off the ancillary systems when the starter is pressed. Am I right in thinking that if the Starter brushes are worn you get a poor grounding and the Circuit to the LSR will be open therefore leaving everything off ?.
Thanks
Skunky
Title: Re: To Start or not to start. That is the Question
Post by: Martin on June 04, 2019, 11:18:16 PM
Pull the starter and clean and measure the brushes, should take you about an hour. Carbon build up does funny things on Bricks.
Post by: Skunky on June 04, 2019, 11:19:49 PM
Thanks Martin. I'll do it over the next couple of days.
Post by: volador on June 05, 2019, 07:42:06 AM
The load shed relay which has the headlight and some other stuff connected grounds to the hot brush of the starter. If the starter is not energized this provides a path to ground for the relay coil, thus providing current to the headlight, etc.
However, when the starter button is depressed +12v is applied to the hot brush. The load shed relay coil now has +12v applied to both ends of the coil - thus no ground. So the relay turns the headlight and stuff off until the starter button is released.
