TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Soggz on June 04, 2019, 02:01:06 PM
Title: K75c rear shock
Post by: Soggz on June 04, 2019, 02:01:06 PM
Hi. I think the damper has given up. Can it be rebuilt with a new damper? Thanks.
Title: Re: K75c rear shock
Post by: volador on June 04, 2019, 04:29:00 PM
What's a bloody damper?
Post by: Martin on June 04, 2019, 04:48:00 PM
Most shocks can be rebuilt depending on brand what brand is it? We can get the OEM one rebuilt and upgraded locally.
Post by: volador on June 04, 2019, 04:51:59 PM
Punt old damper to the bin. Install new damper
Post by: Soggz on June 04, 2019, 04:53:32 PM
ok, may go for a YSS(?) one?
They any good?
Post by: Soggz on June 04, 2019, 04:55:22 PM
It’s the hydraulic part of the rear shock. The long silver bit that goes into the shorter fatter black bit, inside the curly black or red bit...
Post by: volador on June 04, 2019, 05:17:05 PM
They any good?
YSS = Bin
Ohlins, Wilbers, Yacugar, Mupo
Post by: Soggz on June 04, 2019, 05:20:27 PM
YSS = Bin
ok for on a budget, though, until a better one can be afforded?
Post by: stokester on June 04, 2019, 06:32:06 PM
They any good?
The YSS was recommended to me by Ted Porter < http://www.beemershop.com (http://www.beemershop.com) > as the best value for our bikes.
I like mine.
Post by: The Mighty Gryphon on June 04, 2019, 06:49:32 PM
My YSS shock seems to work rather well.
Post by: natalena on June 04, 2019, 06:52:35 PM
YSS = Bin
Just for clarification, why bin the YSS?
I ask because I have an MZ366 YSS, and although it took a while to set up due to lot's of damping adjustment and infinite preload, it may well be the best "bang for the buck" shock I've ever owned.
Post by: Chaos on June 04, 2019, 08:30:02 PM
Progressive 412 is probably the cheapest at around $300, better than stock but pretty basic.  One nice thing is you can order the 3/4" shorter version if you'd like to lower your seat a bit.
Post by: Soggz on June 05, 2019, 02:58:13 AM
The YES one I saw for a k75c was £132.00. I’m gonna get that one, for now, as my one one my bike simply dosnt move!
Post by: Soggz on June 05, 2019, 02:59:52 AM
That one will be ok, won’t it? I’m a bit skint at the moment, but want to ride my new (to me) k bike!
Post by: volador on June 05, 2019, 03:28:49 AM
Rebound adjust of 35-40 steps is "infinitely" too much, Preload is not double nut and the locking screws are a fail.
Cornering stability is shallow when tires on edge and compression/rebound damping over the bumps at speed are irregular and unpredictable.
If your shredding through the twistys and dragging pegs on a regular basis this shock will leave you uninspired.
YMMV
Good luck with your damper.
Post by: Soggz on June 05, 2019, 06:23:15 AM
YMMV
yeah. I’m not Carl Foggerty, but my bike is giving me back ache. Just want one that takes the huge bumps out, that’s all.
Post by: natalena on June 05, 2019, 07:23:16 AM
Yep, on this side of the pond, most don't ride like Dave Emde ;) The YSS, although not track worthy, is impressive for cost basis. Don't worry about the adjustment nut...I put a dab of paint once set, and it hasn't moved, but then again, I don't ride like Freddie Spencer or Hailwood.
Post by: The Mighty Gryphon on June 05, 2019, 08:34:58 AM
YMMV
Crap!  I was hoping to grind the cylinder head off of the RS with my new YSS shock.   Seriously, around here the big thrill in the twisties is not falling into a big pothole or lowsiding on a pile of broken pavement debris.
With the incredibly crap pavement here in upstate New York the best I can hope for is not to bend up the rims too bad.
Post by: K1300S on June 05, 2019, 10:20:00 AM
what's a bloody damper?
It is the correct term for what is commonly (incorrectly) referred to as a "shock".
The SPRING absorbs shocks (bumps).
The damper reduces the oscillations of the spring due to the bump.
Post by: K1300S on June 05, 2019, 10:35:41 AM
YMMV
Different experience here..
I have Fox remote damper on one k75.
Progressive 465 on another k75.
Full Wilbur's setup on k13.
And yss on the k11 in my shop.
Yss had been excellent over last year and couple thousand miles, mainly in the Twisties.  Easy to adjust, handles very well, and no issues with preload or locking screws.  It ain't a Wilburs or a Fox, but it is certainly a solid damper for the money.
Post by: Gr-Racing on June 05, 2019, 10:43:41 AM
any first hand review on the Biturbo shock or Hyperpro?
thanks
(https://i.ebayimg.com/images/g/VlIAAMXQCndRhH0K/s-l500.jpg)
(https://i.ebayimg.com/images/g/x9EAAOSwwK1c7mKR/s-l1600.jpg)
Post by: Laitch on June 05, 2019, 10:52:42 AM
:threadjacked This topic seeks recommendations of orthopedic moto appliances for semi-invalids, not racing equipment.
Post by: Gr-Racing on June 05, 2019, 11:10:49 AM
Did not see any were from OP about orthopedic moto appliances for semi-invalids, just saw a conversation about shocks and since im not looking for race Equipment thought I might share shocks in the same price range but thanks for the help, I will make a post in the race section... if I can find it.
Post by: Gr-Racing on June 05, 2019, 11:12:11 AM
sorry OP
Post by: Soggz on June 05, 2019, 02:19:21 PM
It amuses me, that over there, what we call a road,here,is a pavement, there. Our pavement, is your sidewalk. You would get banned from riding, or kill someone, if you rode on the pavement!
Post by: Laitch on June 05, 2019, 04:38:06 PM
It amuses me, that over there,. . .
Over here, a strip of land dedicated to motorized vehicular traffic is called a road or highway. A road's surface can be dirt, gravel, or pavement. Pavement is usually made from bricks, cobblestones, asphalt, concrete or gold.
Post by: K1300S on June 05, 2019, 08:11:57 PM
multiple nations divided by a common language....:-)
Post by: billday on June 06, 2019, 06:12:34 AM
In America, we park in the driveway and drive on the parkway.
Post by: Laitch on June 06, 2019, 06:15:13 AM
:clap:
Post by: Soggz on June 06, 2019, 12:35:32 PM
I guess our way is the right way, as the native America Indians didn’t have roads till you lot turned up over there!
Post by: Laitch on June 06, 2019, 12:49:16 PM
I guess our way is the right way . . .
Your way is the left way. We drive the right way. :giggles
American "Indians" came from Eurasia, where they also drive the right way.
Post by: volador on June 06, 2019, 01:21:41 PM
You suggest I paint my $400 damper to lock the bloody Pre-load
Which brand do you recommend Interlux,Sherwin Williams,Blue Water,Benjamin Moore,Pratt&Lambert...?
Post by: natalena on June 06, 2019, 04:16:44 PM
Your Mother didn't hug you much did she? Don't worry, you're accepted here, and there's no need to lash out.
Post by: billday on June 06, 2019, 04:54:00 PM
Of course they had roads. They had commerce across the whole continent! There's a great book about it called 1491.
Post by: volador on June 06, 2019, 05:44:20 PM
Where's your sense of humor, my remark was tongue in cheek
Post by: K1300S on June 06, 2019, 07:04:55 PM
No, he did not suggest you use paint to lock anything.  The paint is to mark it's position so you can tell if it moved.  Very common method to check fasteners.
I like interlux... Especially the anti fouling version!
Post by: bocutter Ed on June 06, 2019, 08:02:30 PM
I think it's BASF who has the proper paint codes.
Post by: natalena on June 06, 2019, 10:10:30 PM
Likewise. Now I know why emoticons are important. ;)
Post by: Soggz on June 07, 2019, 05:36:41 PM
Got the £132.00 YSS today. Fitted it, it’s ok!
Post by: Soggz on June 15, 2019, 04:22:04 PM
Send it back, got them to put a bigger spring on, even better for two up and luggage!
