MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: fatallightning on May 31, 2019, 12:38:47 PM
Title: WTB: fuel level sender for a k75
Post by: fatallightning on May 31, 2019, 12:38:47 PM
You know the part, you know why I need it. Anyone holding?
Title: Re: WTB: fuel level sender for a k75
Post by: Laitch on May 31, 2019, 02:06:55 PM
What you needs depends on the year of your moto's fuel tank. Does the part have a float or not?
Post by: rbm on May 31, 2019, 07:25:55 PM
He's got 87 k75 in the signature so we'd have to assume it's a float type.
Post by: Laitch on May 31, 2019, 07:28:55 PM
. . . we'd have to assume it's a float type.
Considering parts are swapped on these motos with regularity and confirmation is a simple process, assumption seems as pointless here as anywhere else.
Post by: volador on June 01, 2019, 02:12:25 AM
I bet you a Latte there's a metal rod thingy with a large ping pong ball stuck on the end inside OP's fuel tank
Post by: Laitch on June 01, 2019, 08:54:57 AM
You're on! rbm can hold the PayPal notes, and fatality can supply photos.
Post by: The Mighty Gryphon on June 01, 2019, 10:05:58 AM
If you need the ping pong ball on the coat hanger thingie I have one.
Post by: Laitch on June 01, 2019, 01:12:56 PM
Dually.
Post by: volador on June 01, 2019, 01:30:34 PM
Dually.
Are you holding a Physics webinar?
Post by: Laitch on June 01, 2019, 01:48:28 PM
No. That was a pie plate I just put into the sink. Update your LIDAR.
Post by: fatallightning on June 01, 2019, 03:18:56 PM
My bad for not clarifying, I need this guy. Part number is 62 16 1 459 565. I'm having intermittent fuel pump issues and I'm pretty sure it's at the fuel level sender pass through.
(https://cdn3.volusion.com/2b95c.ejoz3/v/vspfiles/photos/FLF-565-2.jpg?1475162745)
Post by: volador on June 01, 2019, 03:37:31 PM
MMmmm I love pie. I'll have a piece with my Latte
Post by: stokester on June 01, 2019, 03:41:07 PM
I would check the 4-pin connector first.
Post by: Laitch on June 01, 2019, 03:47:37 PM
OK. To me it looks like a marshmallow, and a medium-sized one at that. If rbm says it's a large ping pong ball instead of a marshmallow, send me your PayPal address.
(https://7img.net/users/4211/29/48/93/smiles/177381.gif)
Post by: fatallightning on June 01, 2019, 05:04:04 PM
Gave em a good wiggle and they've also already been replaced with 4 pin trailer style connectors. I should pull the float and check it for continuity and resistance.
Post by: volador on June 01, 2019, 05:52:17 PM
  4 pin configuration on the male end of the Petrol Gauge Level Sender
1.Brown-is ground continuity to the larger diameter ring terminal
2.Green-is 12V continuity to the smaller diameter ring terminal
3.Yellow-is fuel level
4.White-is 4 litre reserve indicator
Remove the ring terminals from the fuel pump to perform the continuity test
Post by: volador on June 01, 2019, 08:54:32 PM
We don't need to bug rbm. We're good. Cheers
Post by: Laitch on June 01, 2019, 09:09:26 PM
We're good. Cheers
It's settled then. You owe me a latte. I want one with a fried egg floating in it like yours. I'll be in touch. :giggles
