MOTOBRICK.COM => Welcome To Motobrick.Com => Topic started by: Larryh on May 31, 2019, 03:24:32 AM
Title: Hi from Bristol, UK
Post by: Larryh on May 31, 2019, 03:24:32 AM
Hi folks
Just sayin hi. Managed to complete the entry exam that is the registration procedure! :)
Just bought a '91 K100LT with what seems like a genuine 20k on the clock.  Hoping the lack of mileage isn't gonna throw up issues, but for the last few years at least it has been doing 1-2k per year based on MOT history.  Front brakes sticking at the mo so gonna give them a service, as well as the rest of the bike, and hopefully get it MOT'd and on the road soon in time for putting some miles on it this summer!
Title: Re: Hi from Bristol, UK
Post by: Laitch on May 31, 2019, 06:44:47 AM
Welcome, Larry.
Try completing the photo posting exam by showing us a few photos—upside up, preferably—of your moto. I hope you and your Brick have a happy life together.
Post by: natalena on May 31, 2019, 12:55:20 PM
Welcome, and with the recent MOT's, at least the brick is a runner. Lot's of useful info here. Cheers
Post by: Larryh on June 13, 2019, 12:31:36 PM
Finally I have a couple of pics!
Post by: Larryh on June 13, 2019, 12:33:28 PM
And this one.  Reckon my front brake is still sticking!
Have cleaned the calipers up already so will do a bleed next and then maybe a m/c rebuild if still sticking.
Post by: Laitch on June 13, 2019, 01:05:30 PM
:hehehe That must be exciting! With a little practice, you might be able to contract out for light job site grading, or potato hilling. Thanks for the photos.
Post by: The Mighty Gryphon on June 13, 2019, 01:33:27 PM
Beautiful bike!  Get those calipers unstuck before you mess up that sweet paint job.
First thing I would do is to disconnect a line at the caliper.  Try the brake and see if any shit comes out of the banjo fitting.  That would indicate a decomposing brake hose lining.  I bought a bike last year that had several years of very light use that had the same problem with sticking front brakes.  Replacing the lines with stainless cured the problem.
Fortunately, the banjo fitting does a pretty good job of acting as a filter to keep the shit out of the caliper.
Post by: Larryh on June 14, 2019, 03:42:43 AM
Ha - thanks folks!
Cheers for those pics TMG - can't believe the crud in there!
My best guess at the moment is that something is blocking the m/c return hole for the brake fluid - I was thinking it would be swollen seals but based on your pics it could easily be a lump of that crud!
Basically, the brakes are fine when cold, but as I ride and the fluid warms up, the lever gets 'tighter' - i.e. the free movement before the bite point reduces - until the lever is very firm, implying that the fluid (probably contaminated with loads of water) is expanding and isn't able to return to the m/c.  This is also in line with what I found when cleaning the calipers - I just could not push the pistons back in by hand without cracking the bleed nipple, so even when cold, the brake fluid isn't returning to the m/c.
Guess I'll be doing the lot for safety - m/c, lines and fluid.  The caliper pistons were actually surprisingly free moving.
Post by: natalena on June 29, 2019, 03:03:36 PM
* Gravel.jpg (89.14 kB . 432x576 - viewed 854 times)
If ever there was a need for a tailhook. ;) Good job stopping her before the garage.
Post by: Soggz on July 08, 2019, 05:25:21 PM
Hi mate,from just down the road,other side of Bath.
Post by: DJEwen on July 09, 2019, 08:44:08 AM
* Side.jpg (124.66 kB . 767x576 - viewed 829 times)
* SideFront.jpg (124.3 kB . 767x576 - viewed 766 times)
Outstanding! She looks lovely! I'd like one just the same in that color too. Happy Bricking  :mm
Post by: Skunky on July 26, 2019, 02:11:44 AM
Hi from Derby, just replace the brakes from the reservoir down. You might get away with the caller but is it worth the risk. If the AND is good that will only make it worsr. Plus a gravel drive is not the best environment for rear wheel braking 😅
Post by: Soggz on July 26, 2019, 02:45:24 AM
Done it yet? What was it causing the problem?
