TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k on April 07, 2019, 02:32:08 PM
Title: K1100 Won't Crank
Post by: k on April 07, 2019, 02:32:08 PM
Battery is charged. Bike is in neutral with stand up. Makes a high-pitched whine when I hit the button, but the starter doesn't crank.
All solutions appreciated.
Title: Re: K1100 Won't Crank
Post by: johnny on April 07, 2019, 03:07:17 PM
1) when did it last run... 2) will it bump start... 3) did you back spin it... 4) take a video with sound and post it here so we can hear it... 5) could be starter spinning and not engaging or could be the sprag clutch needs a flush (http://bmwmotorcycletech.info/kstartersprag.htm) amoungst other things...
Post by: k on April 07, 2019, 05:14:57 PM
Starter isn't spinning. Not a sprag issue, at least not yet.
Ran in November.
Flat here. No bump start.
Tried backspin, moving in gear, and trying to make the starter advance a degree.
Post by: Scott_ on April 07, 2019, 05:18:58 PM
What happens with the lights(headlight, dash lights, etc...) when you hit the starter button.
Post by: johnny on April 07, 2019, 05:41:06 PM
has it been on a tender over the winter... or did you install a new battery this spring... or what...
have you serviced the 4 pin...
fully charged... what voltage off and voltage when you hit button...
need audio...
Post by: k on April 07, 2019, 06:11:20 PM
The battery's not the issue. I also tried jumper cables off a car.
Fuel pump spins but the starter doesn't.
Post by: k on April 07, 2019, 07:17:03 PM
Cranks fine. Starts fine. Runs fine. Idles fine.
Battery is toast.
Post by: johnny on April 07, 2019, 07:42:44 PM
need clarity...
cranks fine... starts fine... runs fine... idles fine... you mean last november...
need that audio... and those voltages...
Post by: Laitch on April 07, 2019, 09:12:56 PM
Cranks fine. Starts fine. Runs fine. Idles fine. Battery is toast.
These two quotes don't square. How did you start it?
Post by: k on April 08, 2019, 09:17:47 PM
Conflicting battery readings. Used a jumper box, and it fired up almost immediately after being parked since November.
