TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: stokester on March 19, 2019, 09:42:09 PM
While working on my '93 K75S I had to remove the fuel from the nearly full tank to check the fuel pump damper. This gave me a chance to use the Best Rest MotoSiphon https://bestrestproducts.com/shop/miscellaneous-gear/motosiphon/ (https://bestrestproducts.com/shop/miscellaneous-gear/motosiphon/) that I had carried in my side case for a year or more.
I have to report that like the CyclePump, this product worked exactly as described. It took only a few jiggles of the line to create a siphon and drain the tank.
If you need a good air pump or siphon check out the BestRest products line and review their tests on air and oil filters.
I've had a couple jiggle siphons, one worked great and 2 others were pretty much garbage. Don't remember which brands were which.
