TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Chri5 on March 08, 2019, 01:08:51 PM
Hi
So i was on my way to work pulled out for a slow over take reved up to 3400 ish rev and a horrible noise started so i have put the bike off the road
the engine starts great pulls as normal and idles perfect but im not willing to run high rev with this noise
Ive removed the alternator in the vid ill link in my next post i will be stripping the bike to clutch at the weekend but if any one has any ideas what it might be please shout out
https://m.youtube.com/watch?v=yOYVGZpzzhc
The noise which sounds like the mic cant handle it is what it sounds like the noise comes in at 2500rpm cold and 3200rpm when warm. The noise increases with revs
Did the moto accelerate abnormally slowly when you revved it while riding it?
Output shaft rivets??? They have been known to let go on early model K100 engines. A lot of owners replace the 6 rivet output shaft with a later model 12 rivet shaft.
No the bike behaves normally revving and acceleration seem normal
Yeah output shaft is on my list to inspect ive read the many posts that mention it. am i right in saying its engine out to get to the output shaft
Is there any way to inspect the output shaft rivets with out removing the engine can they be seen throught the crack cover maybe? Weather permitting i should be crack it open sunday but if i can inspect without taking the brick right back i can order the later shaft and have it ready to go as ill be working out side in rainy old britan and the less time i have it in bits the better
It might be possible. Inspect the attached photo supplied in a comment by Spike Cornelius following John Brown's IBMWR essay (https://ibmwr.org/index.php/2000/01/01/engine-output-shaft-noise/) about output shaft gear repair with the engine in frame. A small portion of the output gear can be seen just to the left of the arrow. Cornelius's comment also explains how to observe the gear for problems. Brown heard a different noise than you are hearing perhaps because all the gear rivets broke at one time. His moto wouldn't move by engine power after that.
(http://www.motobrick.com/gallery/1/1601-090319074656.png)
Thanks Laitch thats a useful article
So after some poking around under the crack cover all 6 rivets are there and appear in tacked although one seems to be protruding out more than the others maybe by 1mm as the othere 5 are flush with the gear on crank the other thing i found which i think is the reason for noise is i found about 0.5mm or more axial play in cylinder 1 conrod i believe some engines allow a little play in that direction but cylinders 2-4 are rock solid
Does any one know if the brick should be solid or if there is a tolerance of play along the crack *crank *for each conrod
I would pull the cap and inspect bearing and measure the
crack crank and connecting rod boar.
With a helper turning the rear road wheel, forward and back, in gear, can you see or feel (if lucky) or produce free play between the output shaft gear and damper housing? If so you probably want wd40 on small external bolts for sump and lower crankcase half. Especially also the larger internal bolts, I think 4 or 6 from memory. I had to let them soak for a few days before they would turn.
How many km on your bike and do you think they're genuine?
Does any one know if the brick should be solid or if there is a tolerance of play along the crack for each conrod
That isn't a crack; it's a joint or space. A crack in an engine usually refers to a partial fracture/breakage of a component like a block, cylinder head or pump casing.
The limit for end play of a connecting rod big end bearing is 0.40mm, according to the specs in the BMW K75/K100 2V workshop manual available in Repair Guidance at this site. If end play measures 0.50mm—you're just guessing—that rod bearing in your engine is over the limit. You can measure end play right now using a blade-type feeler gauge. A 0.45mm blade shouldn't fit into that joint. Download the manual and view the engine spec charts in the Engine section.
Visually check for play in the output gear by movement of the crankshaft. Rivets should be tight.
I'm uncertain we've tracked the source of this noise yet. I think you'll need to start disassembly. Does the oil pressure indicator light up?
Don't take seriously advice when it's offered up from somebody's memory; verify it.
A quick correction i ment crank not crack my phone auto corrected
So with the feeler guage should that be placed between the conrod adjacent "weights" im not really sure where i would put them
The bike has 50k on which i have no reason to beleive they are not genuine
The noise can be heard on the video as noise descriptions are some what subjective i would describle it as a raspy rattle it sound like the mic on the video is blowing out but its not thats the noise
When rotating the rear wheel the shock absorber housing on the output shaft visually looked solid to the gear the riverts all felt solid to when poked
I will make a vid of the conrod on cylinder 1 and post it
Just curious, but have you pulled the alternator and checked the monkey knutz, clutch cup and the drive dog? Worn knutz or a bad bearing or splines on the dog can make quite a racket. An easy check is to run the engine with the alternator removed.
Yes Gryph that was my first thought the monkey nuts look new and the bearings are good the noise is persistant without the alternator which is removed in the vid
So with the feeler guage should that be placed between the conrod adjacent "weights" im not really sure where i would put them . . .
The connecting rod and its bearing shells ride on a rod bearing journal. The counterweights are opposite the rod journal. You're measuring the space between the rod bearing cap and one side of the rod bearing journal. See the attached photo. Download the manual. In fact, it's better to have two or more manuals by different publishers so you can get varying explanations.
(http://www.motobrick.com/gallery/1/1601-110319092804.png)
Sounds like what I had, it was the no return valve for the gas , located at the bottom left of the gas tank, the ball bearing comes loose inside the valve and rattles a lot. Only happens on early bricks. Put you ear up to gas tank when you rev the engine.
So ive check the endplay in the conrods and they are all within tolerance although cylinder 1 is greater (<0.3mm) than 2-4 (<0.2mm) im glad about that so im back to output shaft visual inspection even though the riviets all look in place and feel solid in situ im going to have to take it out to have a proper look i let u know what i find but im just not convinced its that is there any other possible culprits it could be Or checks i should undertake before i open the engine up??
. . . im just not convinced its that is there any other possible culprits it could be Or checks i should undertake before i open the engine up??
Grant made a suggestion in Post #17. Why don't you acknowledge it and check that valve? It's inside one of the two hose attachment pipes on the left underside of the tank—a spigot usually removable with a wrench. Soak it with penetrant first to help with loosening it.
Yeah the noise is from by the crank towards the alternator area
The disc are old but the noise occurs when stationary the engine is only a baby with 50k on it
If it's that high we can eliminate the sump area. Look for any worn bearing or loosness on the gearbox side of the intermediate housing (bellhousing thingo between gearbox and engine) hopefully like the alternator drive. Then I spose remove gearbox, hopefully something lose in clutch, or anything on the gearbox side. If still no luck, looks like the intermediate housing has to come off and hope for a worn bearing on the engine side of the intermediate housing.
I think you've missed some of Gryph's advice, Chri5.
Gryph indicates the driving dog should be inspected but you didn't mention inspecting it. You indicated that the drive cushions and bearing looked good to you. It's possible the screw that holds the driving dog to its shaft loosened, the screw stripped, the splines within the dog might be damaged or a combination those conditions. The noise could be from the shaft riding over the dog's splines. The arrow on the attached diagram indicates the driving dog; the photo is a view from the engine side of the dog showing the splines within it. You had better pull the alternator again so you can reach in and check that dog for looseness.
The photo and diagram are from the MAX BMW parts fiche (https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51747&rnd=07242017).
(http://www.motobrick.com/gallery/2/1601-220319094319.png)
(http://www.motobrick.com/gallery/2/1601-220319094403.png)
Have you checked for trombones?
https://youtu.be/_D4reewr9Cc
Good one billday!
Also, check the voltage across the battery for irregularity while noisy.
Does the noise change after pulling in the clutch?
After another sunny days poking around looked at the drive dog and it doesn't look worn or damaged so took the transmission off to investigate a bit more with the intention to have a look at the gearing behind the bell housing for the alternator and found the clutch pressure plate has broken on one of the outer silver coloured metal bands which has proceeded to mince the inside of the bell housing here are some pics
After another sunny days poking around . . .
Thanks for the update and photos. That's an uncommon occurrence but should be relatively straight-forward to repair after you've thoroughly checked the other components for damage.
hmmm, that explains all the noise.
Bonus, good result.
Be careful not to lose the original balance paint marks when you clean the parts.
One component of the balanced assembly—the pressure plate—must be replaced so balance has already been lost. It's likely the entire clutchpack and other small parts should also be replaced after being in that shredder.
My thoughts exactly laitch ive ordered a complete clutch (used )and a bell housing my next thought it what could of caused this, could a poor adjust clutch cable do that damage as i dont know how old the cable is and i also have a stiff clutch arm on the transmission which im going to replace just in case
Probably no need to replace the clutch arm, just disassemble it, clean it, and give it lots of sticky bearing grease when you reassemble it. When everything's buttoned back up, adjust the clutch. And don't forget to grease both barrel ends of the clutch cable -- a binding barrel end at the hand lever is a known cause of clutch cable failure.
I agree it is a strange failure -- one I've never seen nor heard of before. Perhaps a freak defect in the part, not "caused" by anything in particular?
Maybe the clutch pack was too new because, as the song tells us, only the good die young. In this case though, it could be one or more of the clutch cover bolts might have backed out or sheared then a spring or springs fractured from vibration on the locating pins and the whole interior became a bingo cage of shrapnel.
Chri5 will no doubt expand his pictorial review of the crime scene.
So with more of the mystical sunshine out i am nearly back on road just waiting my second set of clutch bolts after first reassembly didnt go to plan and i thought i must of bent the transmission input pin as the gearbox just wouldn't fit but the frame was just out slightly so i slackend it all off and reinstalled the transmission but i only discovered this after i took it all apart again
after examination of the old clutch the only thing i found was the inner plate of the spring diaphram had a little play but my replacement part was the same so i assume that is normal the pins on the clutch cover plate were stright and in tacked and the bolt where all tight on disassembly so freak part defect is all i can come up with but i took the opportunity to give that motor its first deep clean in what i can olny guess in at least a decade maybe 2 and try put the colour scheme im planning for the block on the bell housing
Respect for all the work you've done. Try to keep your swingarm supported, so as not to tear the rubber boot.
. . . i thought i must of bent the transmission input pin as the gearbox just wouldn't fit but the frame was just out slightly so i slackend it all off and reinstalled the transmission but i only discovered this after i took it all apart again
Does the engine's intermediate housing have two alignment dowels installed? Their installation has been recommended to obviate misalignment during reassembly.
(http://www.motobrick.com/gallery/2/1601-060419130026.png)
Did you use a clutch alignment tool?
If not you may need a helper to pull the clutch lever in, but only if needed (or clutch arm if off the bike) while you push the gearbox on. Or install the clutch horizontally to help keep everything concentric.
Push the gearbox fully home before installing the bolts. Use some longer bolts with the heads cut off to help guide you.
Check if the push rod is bent.
Keep the clutch arm supported too, so as not to tear the push rod boot. If torn it is best to replace it now.
Laitch yeah the dowls where in place i did get it back together after slacking the frame blots on right it was out of alightment on the dowls by just a fraction and wouldnt slide on like it has previously so i knew something was a miss
Daveson yes i used the clutch alginment tool i also had a check of the push rod with a dial gauge on the side of the tip a spinning the rod just to be sure and its straight
As soon the bolt on the frame where slacken it slight stright on it was the right hand frame mount on the gearbox just pushing ever so slightly
Once my new bolts arrive for the clutch and going to put the gearbox on propperly with its stand then jack the front of the engine so the bike it off the ground except for the stand and jack and loosen the frame again then redo all the bolts for the frame so engine and gearbox completed this is to try and make sure the frame is sitting propperly on the complete set up unless any one has another way to makesure the frame is on propperly
Are you using a workshop manual to help you, if so which one? There is one on this site, I have it as a book, but I'm not home to read it. It goes into great detail about drive train to frame bolts. I think it has 2V in the title and a reference to flying brick at the bottom of the pages in tiny writing.
Is the problem that the frame and gearbox holes aren't concentric, or is it that there is a gap that closes as you tighten the bolt?
Check the frame to be sure it is an RS model. It has spacers (from memory) and the bolts and spacers must be installed and tightened in a specific sequence for an RS.
Good luck with it.
Im using the haynes manual the right hand gearbox frame mount is what was giving me the trouble just pushing the gearbox to the left and preventing the dowel from aligning thats why im planning to reinstall the gearbox to the engine and then loosening the frame with the bike off the ground so it can sit on the engine without the front wheel or the support i have under the tail of frame interfering with the frames position when im torquing up the frame you are correct about a frame shim which is on the left frame engine mount i will double check the manual for the sequence to make sure i got it right
Goodo, engine to gearbox bolts first.
I think the other manual goes into more detail. Maybe your tightening sequence is wrong. Look for signs of a drop, especially a right hand drop.
Be good to see a photo of it when done.
"As soon the bolt on the frame where slacken it slight stright on it was the right hand frame mount on the gearbox just pushing ever so slightly"
Dude, you gotta slow down and check what you are writing. A period here and there wouldn't hurt either. I'd like to help, but your writing is impenetrable.
I think he is writing with a local English accent, it's probably not Cockney, but I like to think it is. I think he is saying when he removes the frame bolt the gearbox "slides straight"on. To me it's a no no to do frame bolts before gear box bolts, but less effort holding the gearbox I spose.
The dowels were designed to prevent misalignment. The idea is that when they are engaged into the corresponding hole in the transmission misalignment of the transmission with the intermediate housing is not possible, unless the dowels are damaged.
What might have been misaligned was the clutch pack. Check Chris Harris's video showing alignment procedure using the alignment tool. It's part of the spline lube video series.
To echo Gryph's query, frame mounts shouldn't be impeding the installation of the transmission to the engine. It's difficult to understand your description. A photo or two is needed to clarify the problem.
I would also chek if the clutch is properly centered, if it is out of whack a bit it can make getting the transmission back on a nightmare
. . . you are correct about a frame shim which is on the left frame engine mount i will double check the manual for the sequence to make sure i got it right
Are you aware that there is a specific sequence for installing and tightening bolts mounting the frame to the engine?
The right rear bolt that is causing you grief, is the first frame bolt that should be tightened. Haynes describes a very different, and vague, sequence. I wouldn't trust it as a sequence guide.
Im using the haynes manual . . .
I use Clymer's, Haynes, and the BMW k100/k75 2V service manual that is downloadable from this site. The BMW manual is the source of the attached diagrams. If a procedure is unclear or unconfirmed, consult another source, including experienced members of the forum. How the K100RS 2V frame is tightened depends upon how the fuel tank is attached.
(http://www.motobrick.com/gallery/2/1601-080419025745.png)
(http://www.motobrick.com/gallery/2/1601-080419030644.png)
I apologize for my crap English im just a bit of a meff when it comes to writing down what i think i do re-read what i type but i think a Chinese translator would do better
. . . im just a bit of a meff . . .
Thanks for introducing this Liverpudlian term to some of us outlanders. :2thumbup:
Well my clutch bolts arrived so ive finally finished that. I just want to say thanks to everyone. Especially the frame information! Under inspection of the shim spaces some previous owner had put washers in the wrong places. There was no shim on the bell housing bolt 3 on the plug tank frame and there should of been. there was a 1.85mm gap. when installed properly the frame just slipped on. i ran out of light before i put the electrics back together so its not totally finished but the leg work is done. I should be back on the tarmac tomorrow
Yeah baby, bonus, good progress freebizzaro
Well im all done, winner winner khicken dinner. Only thing now is my fast idle light is always on is that an adjustment issue?
It might be, or it could be that the piston on the switch is stuck. Fast idle speed adjustment is explained in the downloadable BMW K75/K100 2V manual here on page 13–06.0. Attached is a photo of the switch.
(http://www.motobrick.com/gallery/2/1601-100419202959.png)
I have found that the adjustment of those switches can be, uh, rather finicky. And difficult to reach. In my case, it wouldn't turn on the instrument cluster light.
Ill have a look tonight. it looks like the rear brake light switch which has given so much trouble over last 3 years constant cleaning and an annual replacement 😢
What is this fast idle light of which you speak?
It is a yellow choke light on the dash, my bike does not have the switch but there is room for it on the loom - the choke connection. Max BMW sell the wiring to add it to the harness, I believe it is part no.
61 31 1 459 569you can add it if you want, I did not bother.
That choke/fast idle light wasn't even supplied in my moto's year of manufacture. Like TMG indicates, you could disconnect it. If a rider can't keep track of when the fast idle is activated and when it isn't without a light indicating its status, motorcycle riding is likely too complicated to pursue. In temperatures down to 20ºF, I shut off the fast idle if it is needed for starting by the time I'm in third gear.
