TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: The Mighty Gryphon on February 28, 2019, 12:04:27 PM
Title: Can I Put 4V Speedo On 2V K100
Post by: The Mighty Gryphon on February 28, 2019, 12:04:27 PM
Does anyone know if a speedo assembly for a 4V K1100 will work in a 2V K100 cluster.  Guy I know needs one, but the one I have is from a K1100.
I can see the scale is different, as well as the sweep angle.  Pulse rate from the final drive is the same, and the odometer is working with similar tire sizes.
I know the fuel lights are different, but that's all I can see as a potential problem.  Thinking I can swap the movement and faceplate keep the old lights.
thanks.
Title: Re: Can I Put 4V Speedo On 2V K100
Post by: bocutter Ed on March 01, 2019, 10:55:18 AM
I think I have a spare good working speedo
Post by: The Mighty Gryphon on March 01, 2019, 10:57:04 AM
Km or miles?
Post by: szabgab on March 01, 2019, 11:21:07 AM
Km or miles?
Ed's will be miles I guess.  If km is needed I have a whole cluster,  I had other things to do,  so I did not put it up for sale as yet...   Clock is not working much,  as it is showing numbers in Klingonese and the lens is cracked,  but everything else works,  as it should...
Post by: bocutter Ed on March 01, 2019, 03:18:53 PM
Km or miles?
I think I got it from California ... so both.
