TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: beemrdon on February 24, 2019, 06:36:29 PM
Title: Heated Grip wiring ???
Post by: beemrdon on February 24, 2019, 06:36:29 PM
Hey guys and motobrick gurus,
My handlebar got bent in an unfortunate encounter with black ice.
Anyway, I got another one off of fleabay and have all the controls loose and ready to be transferred to the donor bar except that I don't know how to get the heated grip wires out of their tiny connector without the probability of breaking either it, the wires or both.
Title: Re: Heated Grip wiring ???
Post by: beemrdon on February 24, 2019, 06:40:43 PM
Here is another view
Post by: rbm on February 24, 2019, 06:59:56 PM
Those appear to be 1/4" spade connectors.  Use a small flat blade jeweler's screwdriver to leverage between the housing and the connector to push the locking tab out of the way.  The locking tab is shown in this picture.
(https://cdn2.bigcommerce.com/server500/55923/products/743/images/1213/5950x1b__83941.1423164709.1000.1000.jpg)
Post by: johnny on February 24, 2019, 08:23:13 PM
i cut all that out and put my heated grips on a heat troller... nothing better... (https://www.warmnsafe.com/collections/remote-control-heat-trollers)
Post by: beemrdon on February 24, 2019, 10:19:51 PM
Thanks JO.
Robert, The 1/4" you mention, these are way smaller than that. ...So you are saying the connector plug is not stock???... It may not be. I am the 3rd owner.
Post by: beemrdon on February 24, 2019, 10:27:23 PM
Johnny.........................Also, I have no idea how to hook the Heat Troller up to my grips????? Wouldn't know where to begin.
Post by: johnny on February 24, 2019, 10:49:09 PM
do you wear heated gear...
Post by: Motorhobo on February 25, 2019, 11:23:06 AM
That looks like the stock connector, and I'm in the middle of a similar issue where one of the grips doesn't work and I'm trying to track it down. Power is getting past that connector so I fear the fault is somewhere between there and the grip, which might entail me having to pull the throttle grip out of the handlebar. The principle is the same as any connector that locks in place using some kind of a tab. You have to find something small and flat enough to get in there and depress the tab while gently pulling on the wire until it comes out. Don't force it though - you have to make sure the tab is pressed enough for the connector to escape...
Let me know how it goes ... I want to get mine done too, it's been out there on the lift for weeks because it's too cold to spend any time out there working on it.
MH
Post by: johnny on February 25, 2019, 11:50:58 AM
the wiors between the undertank connector and the grips is a known fior starter due to their resistenance value...
discerning brickers posiconnect the wiors before the undertank connector and run new wiors to the crash pad and quick disconnect them to the grips...
i removed all wiors after undertank connector... and put coax connections and a wye on my grips... and a powerlet on the crash pad... plug in heat troller to powerlet... plug in wye... bam... adjustable heated grips...
posi locks and posi taps are the brickers friend... (https://www.posi-products.com)
dont over think it...
Post by: Motorhobo on February 25, 2019, 12:00:26 PM
I am totally with you on that Johnny and I'm prepared to do whatever it takes to get rid of that crappy little connector. There's got to be a lot of juice flowing through that thing to heat those grips and I've never been comfortable with it.
First though, I'm going to need a translator to understand your valued input. Posiconnect I assume to mean 'replace the stock plastic connector with posi-lock connectors' like these:
https://www.ebay.com/p/Posi-Products-Posi-twist-Wire-Connectors-18-26-Gauge/1991420292?iid=183177842548&chn=ps (https://www.ebay.com/p/Posi-Products-Posi-twist-Wire-Connectors-18-26-Gauge/1991420292?iid=183177842548&chn=ps)
But I'm not sure I want a heat-troller -- I just sprung for a new heated grip switch for the console and prefer to just use that since I don't need a vest or other heated gear here in Maryland -- just the grips.
So...coax and wye ... a little elaboration or links maybe?
Post by: The Mighty Gryphon on February 25, 2019, 12:13:51 PM
I have had some luck releasing those contacts with an old pointy X-Acto knife blade.
Be very careful, X-acto blades are sharp and can cut you!
Post by: johnny on February 25, 2019, 12:32:28 PM
you have oe 3 position switch... off low high... get your power from the undertank grips wiors and run new wiors...
solder and shrinkwrap... posilocks... spade connectors... there are many choices...
Post by: stokester on February 25, 2019, 02:59:41 PM
With the seemingly endless variety of terminals and connectors used in today's vehicles, I had to buy a universal terminal release set when working at the Chevy shop.
Once you know where the locking tab is located on the terminal it is usually just a matter of inserting a thin metal tool to push it in to release.  Patience and a gentle touch will prevent breaking the terminal or connector.
Post by: beemrdon on February 26, 2019, 12:54:48 AM
Robert, thanks for that pic. I have some jewelers screwdrivers that I'll try this weekend.
Post by: BryanD on March 08, 2019, 08:56:46 PM
Where might I find those?  I haven't seen those at my Harbor Freight!  :O)
Post by: BryanD on March 08, 2019, 09:00:23 PM
Remember to reset that locking pin to it's normal height when you re-insert them into the connector housing.  More than one person (who shall remain nameless :)) has put a connector back in where it didn't lock back in properly.  Then when reconnecting the two housings, the spade is forced out enough to have a bad connection.  On a high current application like heated grips, this is not good.
Post by: beemrdon on March 08, 2019, 11:55:23 PM
The wires would not go through the handlebar, I couldn't get them out. I finally gave up and put the replacement bar on the bike. So now I don't have heated grips.
Anyone know of aftermarket replacements that are good?
Thanx
Post by: johnny on March 09, 2019, 12:34:34 AM
i use symtec... still gotta cut the wiors and fish them through the bars... will need new grips and some honda grip glue...
there are tricks... search symtec here at motobrick.com...
* symtec_heat_demon_heated_grips_750x750.jpg (33.39 kB . 576x576 - viewed 690 times)
https://www.revzilla.com/motorcycle/symtec-heat-demon-heated-grips
Post by: Laitch on March 09, 2019, 06:56:17 AM
I've read several riders' positive reviews of Oxford grips. Here is a how-to (http://www.motobrick.com/index.php/topic,8043.msg59401.html#msg59401)—complete with photo drama—from a member of the world famous MOTOBRICK.COM explaining his experience. You might consider sending him a pm for an update.
Post by: beemrdon on March 09, 2019, 06:51:29 PM
Thanks Laitch and Johnny
Post by: stokester on March 09, 2019, 08:39:35 PM
It's the Lisle Wire Terminal Tool Kit available on Amazon.
Post by: BryanD on March 09, 2019, 09:06:01 PM
Thanks!!!
Post by: beemrdon on March 14, 2019, 11:39:02 PM
I think I'm going to go with the Oxford touring grips that Laitch posted. I don't want to try to snake wires through the handlebar, as some other a-market grips would have you do. That is a tight squeeze and too much of a hassle removing the bar again. Very small diameter opening through the center of the bar.
