TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: awshucks on October 17, 2011, 06:19:16 PM
Ever since spline lube early summer on '85 K100 RS, my speedo occasionally wouldn't start working w/o a finger nail few taps on the glass/plastic face.
This w/e, I was cruising long at about 60 indicated, looked down and the needle was at 0. I tapped the side of housing w/ a pocket knife, still at 60 and it started working again.
Any guesses what/how much this one will be?
Click here: Fix a flaky or inoperative K bike speedometer (http://www.motobrick.com/index.php?topic=449.0)
Also check the wiring harness connector for it.
Thanks, just what I needed. ;D
I'd definitely start with the 2 wire connector coming from the speedo's sensor. It's happened to me before that I unplugged it, plugged it back in and got the same symptoms you have now. Do that again, maybe clean the contacts up this time, and it may just fix itself-- like mine.
greetings awshucks...
speedo only or odo too...
Not 100% sure, but think odo goes at same time. I'll have to check it out in a.m. if it acts up.
everytime i would wash the bug or ride in the rain my speedo n odo would run slow for days n sometime weeks... then all of a sudden it would be ok...
i always thought it was the sensor wire cause both ran slow....
Gee, How time flys! I wanted to let y'all know, it appears to have been a little crap on speedo pickup in final drive. I'm several excursions w/ it, and no more problems, knock on wood. Thanks for the help!
Good to hear. And it's always nice when people come back and update tech threads. Thanks.
you know you can chrisschross the sensor wires n run the odo backwards...
you know you can crisscross the sensor wires n run the odo backwards...
Lol, honestly didn't know that, but suspect PO may have!
I just ride down hills backwards.
LOl, better man than me! Speaking of hills, my gravel drive goes up while doing a 180 degree turn. I could handle it easily on airhead, but K w/ higher center of gravity was a thrill, even w/o washouts from rain.
I had a 30" by 5" deep sidewalk dugout and poured in middle of it, all 403". At first it was like trying to keep the bike on a railroad track. ;D This is the easy part, two more curves, the last a sharp 90.
(http://i61.photobucket.com/albums/h74/awshucks47/fallboxerworks005.jpg)
So why do you suppose tapping the speedo face worked if it was the sensor? May still have a flakey connection in the instrument pod, sometimes they go dormant depending on moon phases.
Good question, haven't a clue. It was light/white colored non-magnetic right on what I assume was the magnet, may have jiggled around there?
I know, wishful thinking, I so don't want to have to tear into this, lol.
Did a 500 miler this w/e, tap tap tap. Trip goes out w/ speedo, didn't check odo, but would guess it does too. I got 40 mpg two up [w/ kid].
Will have to address this sooner than later, idiot lights for 7L and 3L are a joke. I need that trip odo.
