TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: jiigan on December 30, 2018, 11:08:13 PM
Title: The jiigan 1985K100 RS Thread
Post by: jiigan on December 30, 2018, 11:08:13 PM
Hey guys,
First post. Just picked up a 1985 K100RS in pretty rough shape. Stripped it down and doing the basics for now. I opened the oil filter housing on the bottom of the engine and a bunch of oil came out (haven't taken the filter off yet) is this normal?
Also I am hearing a clicking sound from the area where the fuel injectors are, any thoughts?
Thank you in advance.
Title: Re: Oil from oil filter housing is this normal?
Post by: K1300S on December 30, 2018, 11:14:06 PM
Yes. The oil filter is IN the sump, not outside.  That is why filters for K's don't have any stickers on the outside
Post by: jiigan on December 30, 2018, 11:19:00 PM
Oh I see, thank you. That is a new one for me. I was used to Jap and Italian bikes before, even had a 2005 BMW R1200 and never came across this. I appreciate the response. What about clicking noise from injector area?
Post by: Scott_ on December 31, 2018, 09:36:49 AM
Now that you have drained the oil getting to the filter, when you add the oil back in, use the center stand when checking the sight glass oil level--- not the side stand.
Post by: billday on January 01, 2019, 08:50:15 AM
Show us your K bike!
Post by: jiigan on January 01, 2019, 08:59:02 PM
Here is the bike so far, pictures from when I picked it up and after stripping the plastics.
Title: Please help identify a yellow wire and a weird switch, thank you!
Post by: jiigan on January 01, 2019, 09:02:14 PM
Hey Guys,
I picked up an 85 k100rs and started stripping it down. Came across a weird yellow wire that is out of place and a weird switch under the left side handlebar. Could you please help identify.
Thank you
Post by: billday on January 01, 2019, 09:06:10 PM
It cleaned up nice.  What are your intentions?
Post by: jiigan on January 01, 2019, 09:12:28 PM
It was filthy but yet it cleaned up pretty well. I am working on doing a cafe racer type of build. So far just going through the hoses in the fuel tank and radiator, doing the basic maintenance, replacing spark plugs, injectors.
The bike has 70k miles, I got it to start but it was smoking a little. I am assuming because it was on center stand for a over a year.
Post by: Laitch on January 01, 2019, 09:25:54 PM
I don't think the center stand was the culprit. Many neglected engines will tend to smoke for a while after starting. Some K engines tend to smoke on startup when parked on the side stand regardless of how often they're run, so the center stand is used when they're parked to lessen that tendency.
Did you change the oil, fuel filter and fuel before you started it?
Post by: jiigan on January 01, 2019, 09:33:41 PM
I meant the side stand.. doh..
I didn't do anything before starting it just ran some seafoam in the gas. Wanted to make sure it starts before I start taking it apart. Since then I changed the plugs, fuel filter, oil filter.
Title: Re: Please help identify a yellow wire and a weird switch, thank you!
Post by: Scott_ on January 01, 2019, 09:56:46 PM
I'd pull of the T cover and see how the wire is connected.
It could be alternate power to the HES sensors, it could be a anti-theft "kill switch", it could be most anything.....
Can't tell 100% till you know how each end is connected, both behind the cover and what is connected on the back of the switch.
Post by: Chaos on January 01, 2019, 09:58:37 PM
Have you tried flipping the switch when it's running?
Post by: Laitch on January 01, 2019, 10:01:27 PM
I recommend doing a compression test and a valve clearance check right now before proceeding with grinding and powdercoating, You might need some of your customization cash to restore the engine to full function. If you establish now that it works well, you'll be ahead in the game.
Post by: The Mighty Gryphon on January 01, 2019, 10:41:12 PM
Laitch, it's a cafe build.
Post by: Chaos on January 01, 2019, 10:57:46 PM
 :hehehe
Post by: jiigan on January 01, 2019, 11:11:12 PM
Thanks for the heads up, I am planning on doing the compression test soon. Didn't think about the valve clearance thought, probably a good idea.
Post by: Laitch on January 02, 2019, 07:18:05 AM
:clap: Please video that moment, jiigan.
Post by: jiigan on January 02, 2019, 01:05:17 PM
Thanks for chiming in. Have not tried to mess with switch while running as I only found it after taking the bike apart. I will open the cover and see where the wire hooks up. The switch has 3 positions it can switch to as well as 3 wires in the back.
Post by: jiigan on January 02, 2019, 11:08:44 PM
Here is the picture of the cover removed and the back of the switch, any ideas?
Post by: Scott_ on January 03, 2019, 07:06:51 AM
Well, looking at the t cover spot, the wire doesn't connect to the HES so that throws out the thought of a security kill switch idea....... and it looks like it does not connect to the switch, so there are 2 different things to sort here...
Does your bike have a water temp gauge?
Follow the yellow wire to the end, I'd almost bet that it was added for a water temp gauge sensor. If I'm not mistaken water temp gauges were not stock on older RS bikes.
As far as the switch, does your bike have heated grips on it now?
Post by: Martin on January 03, 2019, 12:30:23 PM
The switch is next to the steering lock, so I'm guessing either anti theft kill switch or an alarm.
Post by: Andy FitzGibbon on January 19, 2019, 09:35:37 PM
Maybe a high altitude switch for the Jetronic unit? The wire routing wouldn't suggest that, but I thought I would...
Andy
Post by: The Mighty Gryphon on January 20, 2019, 10:42:37 AM
Where is the end of the yellow wire?  Three weeks and still you haven't told us where it comes from and where it goes.  How the are we supposed to tell you what it's for?
Here's my guess based on what I've seen so far.  The switch is for a hyper drive that runs off two battery packs.  The switch lets you select Low power or high power for the hyper drive.
The yellow wire could be for reading the intermolecular spectromatic status of the plasmatron ferdorator in the hyper drive.  If the plasmatron gets too reverse fluxed, the drive goes into overload and there is no telling where you will come out.  That could be dangerous.  Has anyone removed the turbo vortex bifurcator?  That's another place where the yellow wire might go.
Post by: Laitch on January 20, 2019, 12:29:23 PM
Describe exactly the colors of each wire and which wires are joined together at each plug terminal. The dirty condition of the wires in the photo doesn't aid in their identification on a schematic.
Post by: The Mighty Gryphon on January 20, 2019, 12:40:33 PM
C'mon, Laitch, that's what makes this so much fun.  Use your creativity.
Post by: Martin on January 20, 2019, 04:10:47 PM
Duhh :idea2: it goes to the Flux capacitor. He has hit the switch and gone back in time, that's why he is not answering. He is currently being chased by Velociraptors and once safe he'll answer. :sip:
Post by: natalena on January 20, 2019, 07:00:53 PM
Or, he could be minutes into the future, reading these posts, and thinking "I really stepped in it this time." I think it's a "gift" from the engineers who designed the brick, many of whom spent their later years designing wee-toys with intricate bits for Kinder Eggs.
Post by: K1300S on January 21, 2019, 08:11:43 AM
LOL...with the references to "Back to the Future" here....I just saw a DeLorean sitting in the "for sale" lot at a local Army Post.  soo tempting to put a spare blender on the roof...
Post by: BryanD on March 08, 2019, 09:07:00 PM
Every time someone says "Cafe Build", my bike is instantly worth more!  :)
Post by: alabrew on March 09, 2019, 03:15:29 PM
Anyone know anything about that aftermarket windshield deflector? Is it effective?
Post by: mw074 on March 09, 2019, 03:50:18 PM
The Laminar Lip is very effective if you have helmet buffeting issues. Also inexpensive. I have had a couple and they work.
Post by: Nine80seven on March 21, 2019, 07:21:25 PM
Looks like you got a rather rare Fox Twin Clicker shock.  NLA.  But rebuildable.  Nice.  Adjustable compression and rebound.
Post by: natalena on March 21, 2019, 08:29:01 PM
The "AGIP" sticker is super cool ... can't argue with a 6 legged dog breathing fire :)
Title: Will this throttle assembly/tube fit 1985 k100rs. Please help :)
Post by: jiigan on March 29, 2019, 02:27:35 PM
Hey guys,
Still working on the bike. I bought some vortex strap-ons and need to buy a new throttle assembly. Will this one from domino work? Also would i be able to use oem throttle cables or do I need to buy new ones.Thanks in advance for the insight.
https://cafe4racer.eu/en/throttle-control-for-cafe-racer-scrambler-brat-tracker-sport-motorcycle/1044-domino-throttle-control-22mm-vintage-cod-133503.html
Also a couple pics of the engine aftere hours of cleaning. I figured out that wd40 and a wire brush on drill is the only way to go.
Title: Re: Will this throttle assembly/tube fit 1985 k100rs. Please help :)
Post by: jiigan on March 29, 2019, 03:42:52 PM
Stupid iphone... vortex strap-ons... hate auto correct
Post by: jiigan on March 29, 2019, 04:32:56 PM
more than one vortex... what is the outside diameter of the tube...
The tube is 22mm, i think it will physically fit. I am curious about the throttle cable setup thouh.
Post by: johnny on March 29, 2019, 05:04:37 PM
oe is 1 cable... your link is for 2 cable...
when folks axe these kinda questions i gotts to wonder if you gotts a manual or have even eyeballed whats you gotts there...
the moes here can answer mostly any oe questions... butts when you crafting a unique build you are mostly on your own especially when you dont poast photos and specs...
will the domino work... i can make it work... proally not as the maker intended... proally be whack... butts it will work...
Title: Re: The jiigan 1985K100 RS Thread
Post by: Laitch on March 29, 2019, 09:09:00 PM
Be aware that with Domino/Tomaselli products, 22mm can often mean 22.2mm, not 22.0mm, so aftermarket controls mounted on a BMW bar are likely to be loose until shimmed.
Post by: jiigan on March 29, 2019, 09:34:20 PM
You are right, stupid question. Just looked at the old throttle tube that I took off.
Title: Is this normal? Oil leaking from Clutch lever (rear of engine) ???
Post by: jiigan on July 29, 2019, 12:23:35 AM
Hey guys,
I am still working on the cafe race build and have removed the clutch cable. Now there seems to be oil leaking from between the rubber boot gasket and the clutch lever at the rear of the engine. It looks like when I removed the tension the lever separated from the rubber boot, it will go in freely but there is oil that leaked out. Can anyone please elaborate?
Title: Re: Is this normal? Oil leaking from Clutch lever (rear of engine) ???
Post by: rbm on July 29, 2019, 06:20:12 AM
Yes, that's normal.  It's gear oil that bathes the clutch pushrod, which seeps past the thrust bearing.
Too bad that you didn't support the actuator arm when you removed the clutch cable as required.  The spring inside the boot is too strong for the rubber material and the boot tears.  You'll have to replace that part now and its not cheap.
Post by: John Lang on July 29, 2019, 06:23:36 AM
Watch this video by Chris Harris from the 4:00 minute mark.
https://www.youtube.com/watch?v=YCnQE4vQTcs (https://www.youtube.com/watch?v=YCnQE4vQTcs)
Post by: jiigan on July 29, 2019, 09:53:45 AM
Thanks for the heads up, do you mean replace just the rubber boot? I ordered one just in case but it didn't look like the old one had any tares. When I install it, do I have to squirt any oil in there or just replace the boot?
Thanks
Post by: jiigan on July 29, 2019, 09:54:23 AM
Thank you!
Post by: rbm on July 29, 2019, 01:02:29 PM
Thanks
Just replace the boot.  But do it just as you are assembling for the final time.  You don't want to make this mistake twice.  If you really have to install it, then make sure to lash the actuator arm to the case of the transmission with binding wire so that it applies slight pressure to the clutch rod.  That way, the arm is taking the spring pressure and not the rubber boot.
No need to oil upon assembly.
Post by: jiigan on July 30, 2019, 02:10:35 AM
Thank you :)
