TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: andrej_gr on November 21, 2018, 06:54:58 PM
Title: Front brake metal pipe replacement
Post by: andrej_gr on November 21, 2018, 06:54:58 PM
G'day
Would like to replace K75 ABS front brake metal pipe connecting the callipers, with a braided hose. (ABS was removed by PO).
Any concerns? If no, then what's the name of this fitting? Here are the options available on helperformance.com hose builder, if any of these:
Title: Re: Front brake metal pipe replacement
Post by: blackie1 on November 22, 2018, 12:55:02 AM
ride down to your local brake shop and have a chat to them would be your safest bet
no disrespect intended but if you are not  too mechanically minded, i would be using the professionals and I think you would find they could make up a set and fit them at a reasonable cost
Post by: Martin on November 22, 2018, 01:09:10 AM
+1 I have a local automotive brake shop that will make up hoses or pipes on the spot. Either take the bike in or take photos of both ends use a piece of wire measure fitting to fitting.
