TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ChrisJF on October 13, 2011, 04:23:39 AM
As with many other LT's the sidepanel locating clips on my newly-acquired K1100LT have sheared. After consulting this site and others here's my solution
(http://i1034.photobucket.com/albums/a423/ChrisJF3/panelcliprepair.jpg)
- a plastic-coated 12mm tool clip (lightly greased for ease of fitting)
- a small self-tapping screw
- a desktop PC self-adhesive rubber footmount (or similar sized rubber plug)
- Velcro or similar
after adjusting positions &c it works well - no more "heart-in-mouth" dramas when removing the panels.
I like it - what is the source of the "tool clip"?
I obtained a set of various sizes on eBay - searched on "plastic coated tool clips".
McMaster-Carr:
http://www.mcmaster.com/#tool-clips/=f6qzqz (http://www.mcmaster.com/#tool-clips/=f6qzqz)
I was lucky to find an OEM clip from someone parting out a K1100LT (he just cut up a piece of the side panel & sent it to me).
Question:
How does one get the old clip off cleanly?
I've never done any bodywork so any tips/instructions appreciated.
Sanjiv
As questions are still out there, how about the part (98256) that Motobins in the UK sell?
Here (http://www.motobins.co.uk/displayfinal.php?q=98256&go=GO)
Could possibly be used, with the aid of a dremel and JB weld or similar.
The downside is that it only hooks on the upper part on the rubber piece on the frame.
Inge K.
K1100RS battery cover repair:
Dremel cut-off wheel to remove old broken clip to flat.
Added a spacer of ABS plastic.
McMaster-Carr (http://www.mcmaster.com) part number 1723A63
