TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JPaganel on September 28, 2018, 09:09:17 PM
I think there is an issue with my throttle cable. Idle increases when I turn the bars right, so it seems like it's getting pulled.
What is the correct way for it to be routed with the C style small fairing?
For future reference, I figured it out.
The cables are supposed to go between the rubber pad where ignition lock sits and the dash, and then between a fork leg and the head tube and into the frame.
If cables are routed outside the fork, when you turn it presses on them and pulls them.
