TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: El Barto on September 23, 2018, 03:48:22 PM
Title: Koso speedo with oem speed sensor?
Post by: El Barto on September 23, 2018, 03:48:22 PM
For my enduro project I’m using a 3.O and a Koso speedo. Is it possible to use the oem speed sensor as there is only one wire from the 3.0 going to the speedo and the Koso has a 3 wire connection?
Title: Re: Koso speedo with oem speed sensor?
Post by: rbm on September 29, 2018, 09:26:04 AM
When you say "3.0", are you referring to a MaruLabs BEP 3.0?
If the answer to that question is "yes", then you pick up the signal for the Koso speedometer from the SPD output on the BEP.  That output will go to the speedo input on the Koso.  The black ground wire from the Koso will go to ground on the bike and the remaining wire you just ignore (because is normally is used to provide power to the Koso sensor).
Post by: El Barto on October 05, 2018, 02:11:01 PM
 Thanks!
