TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ileumi on September 19, 2018, 08:16:35 AM
Title: No spark 1 and 4 ***SOLVED***
Post by: ileumi on September 19, 2018, 08:16:35 AM
Hello. Still fighting with cafe racer...
Ok. Finaly I find problem with loss power. Cylinders 1 and 4 are cold.
No spark on them.... What I Know? Ignition coils are fine. When I change control wires to coils, spark losses in 2/3 and 1/4 lives.
Ignition output stage  fine. My friend borrow me another, and problem wont fix.
I read fault digits in motronic, only hall sensor 2 is active but I think that is "ghost".
I test sensors with led-indicator and both of are fine.
So far, so close? Anything hints?
Kiitos etukäteen :)
-Ike-
Title: Re: No spark 1 and 4
Post by: ileumi on September 19, 2018, 08:56:52 AM
And +12VDC inputs both of coils, when power is on.
Post by: Laitch on September 19, 2018, 10:22:49 AM
When you blocked each sensor's gap the light shut off?
Title: Re: No spark 1 and 4 ***SOLVED***
Post by: ileumi on September 19, 2018, 11:54:47 AM
Yes Laicth, it will shut off. In test I use normal Duspol universal electric tester.
Problem was worn pin in Motronic. That pin feeds ICU.
-Ike-
