TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Roland on August 13, 2018, 06:16:00 PM
Hello! I am trying to find the original bmw hole pattern for the from the of the final drive where the swing arm meets the drive. What are the dimension and angles involved in that layout? does anyone know where i can get the original bmw hole schematic for that area of the bike? I have tried measuring the spacing with calipers and using trig to find the unknown dimension but That is all guess work at this point. It would be very helpful if i got the actual numbers for the bolt spacing. thank you! cheers :beer:
How about using a Bolt Circle Diameter calculator to get the BCD (https://littlemachineshop.com/mobile/bolt_circle_dia.php) and then a Bolt Hole Pattern Calculator to get the layout (http://www.doov.com/cgi-bin/bolthole.cgi).
