TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Billk on July 30, 2018, 12:02:39 AM
Today I removed the rear ABS module located in the right rear. I now have a blinking ABS light, which I read can be shut off by removing the bulb in the pod or by removing the ABS relay under the tank. Hopefully this will solve that. My question is, will this also turn off the 3rd light in the Central instrument unit that looks like a triangle with an exclamation sign in it.
1995 K75
If you removed the relay, I would suspect that by now you have seen that the triangle light goes out when the front and rear brakes are activated, lighting the brake light. That light stands alone on non-ABS bikes and only indicates a fault in the tail or brake light circuits.
