TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: cush on July 24, 2018, 09:49:54 PM
Title: Parking Lights stay on
Post by: cush on July 24, 2018, 09:49:54 PM
Hi,
I'm new to the forum and this is my first post.  I have a '92 K75.  Purchased last September in TX with only 4600 miles!  Rode it a bit there and then it sat for the winter.  June of this year I rode it back to Denver and have been putting the miles on...it currently has 9242.  I completed the Iron Butt Saddlesore 1000 two days ago doing 1,040 miles from Chicago to Denver.  The last 230 miles of that trip was done in heavy rain.  The bike runs great and I have not had any issues.
Today, we had very heavy rain and hail for about 30 minutes.  Sadly, the bike was stuck outside without any options.  It rained very very hard.  I went out to check on the bike and everything looked fine, except that the parking lights were on (front small headlight bulb and rear taillight).  The keys were in my pocket.  I checked the bike, and it started fine, and ran it around the block without issue.  I turned the bike off and removed the key.  After about 3-5 seconds the parking lights came on.
I've pulled it into the garage and dried as much as I can..removed the seat.  The lights stay on so for now I have pulled the fuse to save the battery.  As this bike is new to me, I'm not sure if this is a common thing or where to look.  My guess is water got in somewhere but not sure where?
Thanks in advance for any advice!
-jcc
Title: Re: Parking Lights stay on
Post by: johnny on July 24, 2018, 09:57:42 PM
id remove the parking bulb and the tail bulb while it sits and put them back in while riding...
Post by: Martin on July 24, 2018, 10:00:58 PM
Welcome to the asylum. The parking light is activated from the ignition switch. They do require periodic cleaning as do most of the electrical switches and connectors. You can cheat and spray electrical contact cleaner into the switch in the hope that it will solve the problem. Or you can do it properly and pull the switch apart and do it properly. However you will need to take care as there are many small parts that will attempt to escape and will never be found. Disassemble in a large box lined with cloth to reduce the chance of a ricochet. A product called DeoxIT will become your best friend used in cleaning contacts switches and connectors.
Post by: cush on July 24, 2018, 10:05:24 PM
Ah, got it.  Thanks for the quick reply.  I'll dive into the switch and see what kind of trouble I can get into.  Of course I'll cheat first because I can...but will pull the switch.  Thanks for the advice of escaping small parts...you've saved me a huge headache.
- jcc
Post by: The Mighty Gryphon on July 24, 2018, 11:34:31 PM
+1 on cleaning the ignition switch.  Someone may have put a bunch of LockEase in the lock, and then the rain may have washed some graphite(an electrical conductor) from the LockEase into the switch.
Not sure if your switch is the same, but here is a procedure for disassembling and cleaning a K bike ignition switch:
Post by: rbm on July 24, 2018, 11:35:11 PM
Instructions here:
http://www.ibmwr.org/ktech/clean-ignition-switch.shtml
http://technik.flyingbrick.de/images/6/6f/61_zuendschloss.pdf
Post by: cush on July 24, 2018, 11:47:11 PM
Thanks Guys.  That will be the project for tomorrow.  I'll pull the fuse for the night once I get home.  I'll let you all know how it goes.  Cheers.
- jcc
Post by: cush on July 25, 2018, 01:15:40 PM
Any advice on removing the setscrew?  Mine is rusted pretty bad and I fear I may strip it....
Post by: beemuker on July 25, 2018, 02:43:59 PM
Get your torch out and heat it up real good. just kidding. dab some liquid bolt remover stuff on it, let it set, and make sure your screwdriber fits real good, and carefully try it. if it's a no go , dab some more, try tightening/loosening, back and forth. just keep at it , it should loosen up. you can tap on  the screwdriver head  to try to break it free.
Post by: The Mighty Gryphon on July 25, 2018, 03:09:27 PM
+1 on the liquid wrench.  Don't be in a hurry.  Use the soak time to get a screwdriver that fits snugly in the slot and work it loose as Beemuker suggests.  I'm pretty sure the screw is in plastic so it shouldn't be impossible to get out.
Post by: cush on July 25, 2018, 03:17:46 PM
Thanks all.  I'll take my time.  In the slim chance that it gets stripped  :nono do I have options?  My guess is that it's never been removed in its 26 yr old life...
Post by: beemuker on July 25, 2018, 03:25:34 PM
There are always options some just aren’t any good you’ll get it out don’t worry it’ll probably come right out my motto is fools rush in where angels fear to tread
Post by: Motorhobo on July 25, 2018, 04:08:31 PM
I just dealt with the ignition switch. Don't try to do it in situ. Disconnect the cable and take it to a workbench and do it over some kind of tray. In particular, there's a tiny little ball bearing that works as a detent for the three position switch. Drop it and weep.
Post by: Martin on July 25, 2018, 06:22:52 PM
When you do get the screw out try and find a stainless replacement. If you can't find a replacement at least coat in Never Seize or Copper Coat, this will at least give you a chance of removing it again. :2thumbup:
Post by: cush on July 26, 2018, 09:49:25 AM
In the end. that screw did not come out.  Thanks to the suggestion from @Martin, I was able to use electrical contact cleaner and fix the problem, for now.  I'm looking for a new ignition switch to replace the original.  However, after removing the switch completely and taking it to the workbench (thanks @Motorhobo) I got to thinking about another solution.  Would there be any problem with bypassing the original ignition switch all together?  My thought is to connect the two gray wires, and then wire the green and red to a simple switch and conceal somewhere...but still within easy reach.  I'd still leave the the original housing and key cylinder in the dash, so it would look like you needed a key to start the bike, but in reality would just need to flip the new switch.   Am I way off here?  Bad idea?
- jcc
Post by: Laitch on July 26, 2018, 09:59:53 AM
Look here (http://www.k100-forum.com/t12180-k100-ignition-switch-replacement).
Post by: cush on July 26, 2018, 10:04:22 AM
Perfect @Laitch, thanks!
Post by: zenitramnaes on August 10, 2018, 10:35:50 PM
Really glad I read this. Picked up a k100 last week and I've been slowly going through it fixing everything. Parking brakes stays on without any of the brake switches plugged in. I'll try this tomorrow and hopefully will solve my light issue.
Post by: alabrew on August 11, 2018, 12:34:27 PM
I added a flip switch to my '91 when I broke the ignition switch by dropping it while lubing the head bearing. I think about fixing it, but that is about as far as it has gotten. =-}
Post by: alexg on August 11, 2018, 10:17:39 PM
Not to discourage messing with the switch, but are you sure that there is a problem? My key comes out in two positions: on one of them, the parking lights stay on. This is by design, so you can have the key in your pocket while the bike is still visible at night if needed.
Regarding leaving the bike in the rain, I always carry a sturdy plastic bag to go over the meter and switch. I have been considering a 1/2 bike cover for a more elegant solution.
Post by: zenitramnaes on August 11, 2018, 10:20:03 PM
This ended up being my situation. On my Honda CB the second position is start and the third position is parking lights. Too be fair though, I picked up this bike last week. On the bright side, I have a really clean ignition switch.
