TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Gru on July 24, 2018, 11:36:45 AM
I have a K75, 1995, with 3.0 tear three spoke wheel. I want to put a 15/70/17 rear wheel on, has a shim in the wheel, but the radial is 11mm wider than the stock bias tire. will it work, or will I have to add another shim.
i went 3 spacers with no adverse effects no tior rubb no off tracking whack...
all these things are tweaked... frames swingarm bushings wheels... gonna have to mess with it...
i can tell you to check tior rubb while the tiors are hot and loaded...
Too much shimming and you'll scrape the centre stand on the other side.
The shims are closer to 1.3mm, hope three will be enough. Tires ordered, shims waiting to have some fun getting things lined up.👍
