TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: schrocketeer on July 17, 2018, 09:38:16 AM
Is there an insert for the centerstand, to fill the holes, and provide a resting surface, other than the steel tubing?
It seems a piece of hard plastic (nylon, ABS, etc.) could go in to the hole with a slight interference fit, and then have a flat spot on the bottom to rest on.
Rubber caps plug the ends of oem stand assemblies. That's about it, so far.
(http://www.motobrick.com/gallery/1/1601-170718102245.png) Diagram from Max BMW parts fiche (https://shop.maxbmw.com/fiche/PartsFiche.aspx).
