MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: oneplustwo on July 07, 2018, 12:41:45 AM
Hi folks - Not sure if any of this stuff is worth anything but I figured I would give it a shot. All prices negotiable. Pick up in or around San Francisco. Actual shipping added once deal settled.
Instrument cluster - $200
Hard bags - $140 for both (both sides could use a new hinge piece. Have one key.)
Hard bag rack/brackets - $50 for both
Saddle - $100 No tears or rips or holes
Headlight, turn signal shroud - $50
Rear tail section - cracked and faded - free
Other miscellaneous stuff - make me an offer
more pics
Just a suggestion to help everybody out. You are selling a low seat. Most people looking for one want to replace the regular seat they already have. The low seat requires a bunch of extra hardware that isn't on the bike with the regular seat. You might want to make a package of all the parts that go with it, especially those two hooks on the tail cowl. Some of those parts are no longer available and the seat won't work without them.
Thanks for the perspective. I had no idea. In any case, I’ll do what you said. Just need to assemble the bits together. Pictures to follow.
Pm'd on the cases
PM sent on headlight turnsignal shroud.
Use the exploded diagrams on RealOEM to guide you in identifying the parts related to the low seat.
https://www.realoem.com/bmw/enUS/showparts?id=0574-USA---K569-BMW-K%2075%20C%20(0564,0574)&diagId=52_3686
Headlight shroud sold. Saddle bags have interest.
Hi,
Any chance you have the coolant reservoir? Mine decided to crack (the little see through level part) and spray hot coolant in many directions.
I'm also in search of front and rear master cylinders (however I might be able to rebuild those) and possibly a good quality shock.
Thanks.
James
I think I do have the coolant reservoir. Front master cylinder too (and both left and right control assemblies actually.) I'm going to reuse the rear master cylinder. And I'm keeping the Ohlins shock that came with it so can't help you there.
PM me for what you think a fair offer is for the reservoir and the front master cylinder. I'll probably just send you the whole right side assembly.
Hi,
Thanks.
James
PM sent on rear tail section
PM'd for handlebar cover etc.
If you have ALL the parts for the seat and it is in good condition I would be interested. Like was mentioned, you can't find the parts no matter what the condition the seat is in.
Do you still have the rubber ignition/switch pad?
Did you find the parts for the low seat? Very interested. Thanks!
Sorry, I took a first look but didn't find them but I'm sure they're around somewhere. I'll take another look and get back with photos.
Hi,
Thanks.
James
Be careful on the reservoir. I got one off eBay once that had the outlet port coming off the wrong side and it was useless. I ended up springing for a new one because that part tends to corrode so bad around the sight glass, which isn't glass but some translucent abs crap.
hey mang. are you selling your keyed ignition switch by any chance?
