MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: superwesman on June 06, 2018, 01:54:44 PM
Title: unable to attach images to post
Post by: superwesman on June 06, 2018, 01:54:44 PM
hello admins - I'm unable to attach images to posts.  I've tried new posts and replies and I get an HTTP 500 error every time I attach an image.  Can you please look into this?
Title: Re: unable to attach images to post
Post by: Laitch on June 06, 2018, 02:34:01 PM
Which instructions are you using?
Post by: superwesman on June 06, 2018, 03:47:40 PM
I just click the button that says "Attachments and other options".  I wouldn't go so far as to say I'm using any "instructions" just clicking the button and doing the obvious follow-up actions like browsing to find the file and hitting "ok", etc.
Does this require instructions?
Post by: Laitch on June 06, 2018, 04:21:55 PM
It looks like it does in your case. I know they helped me anyway.
Downsize your photos to under 3MB in spite of what you may have read, and what you read indicated that the size limit can vary. I doubt if they need to be more than 300KB to look good enough. Make them 8"–10" wide unless they're of a Sasquatch. Those will need closer inspection to verify if the hair is real.
Post by: superwesman on June 06, 2018, 06:37:14 PM
finally got it, basically all the published size guidelines are wrong 👍🏼 1MB did it
Post by: Skunky on June 09, 2018, 03:29:17 AM
Sasquatch ride k100's, which is why no one has ever caught one. If you look closely at some of the owner photos you may see odd looking facial hair. :hehehe
