TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: stokester on May 10, 2018, 10:42:55 AM
Title: Front brake line/ABS sensor clip
Post by: stokester on May 10, 2018, 10:42:55 AM
I recently replaced the brake lines with a Spiegler set on the '93 K75S.
The lines are more stiff and cause the clip on the front fender to pull out.  I think the clip itself is weak where it pushes into the fender causing it to pull out with a minimal amount of stress.
Although I could easily make a clip using zip ties I wanted to see if the clip was still available from BMW and cannot find it in the parts breakdown.
So does anyone know where it is or if it is listed?
Title: Re: Front brake line/ABS sensor clip
Post by: Laitch on May 10, 2018, 12:13:55 PM
Photo?
Post by: stokester on May 10, 2018, 12:44:20 PM
Right side of front fender.
Post by: Inge K. on May 10, 2018, 01:28:31 PM
Part # 61 13 1 369 668
Post by: stokester on May 10, 2018, 02:54:04 PM
Thanks much.
I was looking under fender and body parts, not brake.
