TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: kmark on April 10, 2018, 05:20:14 PM
I have a question. Does this cable (under thumb in picture)go to the ground side of the battery? I know the small one goes to the tab on the computer, just wondering about the one with the ringed terminal. I appreciate the help
If the far end of that cable goes down to the gearbox housing on the left side of the bike, then yes it is a ground cable. If it disappears into the relay box, then no it is not a ground wire.
Whatt he said. Other end should be bolted to GB.
Yes, other end is normally connected to the gearbox at the inner mounting bolt for the starter.
