TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Vlad on March 13, 2018, 03:08:53 PM
Title: K75 - chugging at low throttle
Post by: Vlad on March 13, 2018, 03:08:53 PM
Hi everyone. Wondering if anyone has some ideas for this issue. I just started the bike up again after being mostly sitting for the winter. (I had started it a few times here and here to test out new additions and what not, and it ended up killing the battery, but that’s fixed now after it was left on a trickle charger for a few days)
I insured the bike yesterday, changed the engine oil, transmission oil, and final drive oil and took it out for a ride. I also checked the spark plugs and they seem to be in good condition.
What I noticed after a few minutes was it it was chugging at low throttle input. As soon as I pulled a little heavier on the throttle, the chugging went away. It rode the bike for an hour, and the chugging seemed to improve over the durations of the ride. When I was on my way home, it was barely doing it.. but there still is something off, it feels like it hesitateds to give more gas when you first start slowly pulling the throttle. Although at the beginning of the ride I was quite worried because the engine chugging was quite pronounced.
I put some new gas in there and it is doing the same thing.
Any idea what might cause this sort of issue?
Thanks!
Title: Re: K75 - chugging at low throttle
Post by: Chaos on March 13, 2018, 04:16:45 PM
not sure what "chugging" might be, hesitation or slight miss?   I had similar issues years ago, turned out to be water settled at the bottom of the gas tank, a can of HEET gas dryer took care of it.  Or run some Techron fuel injector cleaner through it.  Check the little crankcase ventilation z hose and the throttle body rubbers, could be a vacuum leak. Just guessing but those a some common problems.
Post by: beemuker on March 13, 2018, 04:17:37 PM
how many rpm's before the "chugging" goes away. mine kind of rattles a little at low rpm's. I'm on my 3rd K75, and I think they all did that. I could be wrong. BUT, these bikes love to rev.
Post by: Vlad on March 13, 2018, 06:07:00 PM
Very low rpm probably under 2000. By chugging i just mean the power cuts out and comes back repeatedly at low throttle
Post by: rbm on March 13, 2018, 06:07:47 PM
I've put 2 + 2 together and found the problem is the insurance.  Remove the insurance and the chugging will stop.  :hehehe
Seriously though, I think is might also be injector related.  Did you run fuel stabilizer through the system before you stored it for the winter?
Post by: beemuker on March 13, 2018, 06:10:10 PM
ok, that's not normal
Post by: Vlad on March 13, 2018, 06:42:47 PM
Haha.. no I haven’t put anything but gas in it. Is there some sort of additive I should be putting in there?
Post by: beemuker on March 13, 2018, 08:18:34 PM
yea, if you are having issues, see chaos post above.
Post by: lmiklosy on March 13, 2018, 11:14:02 PM
Remember the Bosch fuel controller will cut-out the fuel supply to the injectors when two conditions are met:  the engine speed exceeds 2000 rpm and the throttle valve switch is closed. When the engine speed falls below 2000 the controller activates the injectors again. If the idle speed is set too high or the fast-idle lever is left on you might feel a chug-a-lug as the engine speed passes through 2000 rpm.  There's a discussion about this elsewhere at Motobrick, look-up "back-firing".      Does that help?
Post by: blackie1 on March 14, 2018, 01:02:25 AM
i'd be giving it a bloody good thrashing to blow out the cobwebs.
Post by: richarddacat on March 14, 2018, 02:12:28 AM
Fuels today will evaporate if additives are not added.
Personally I’ll fill up with non-ethanol and even add Sea Foam or another additive. I do that with all engines that sit through the winter. I don’t have spring starting or running issues as a result.
Sometimes it’s best to drain your tank and refill with fresh fuel.
Definitely run non-ethanol in your lawn equipment year around and that will save some headaches as the years pass.
That’s my two cents.
