TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TX brick on March 11, 2018, 08:10:59 AM
I need the molded hose that goes from the tank to the regulator. Is 13311461011 the correct number?
Yes. :2thumbup:
http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx?&searchtype=partnumber&parts=13%2031%201%20461%20011 (http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx?&searchtype=partnumber&parts=13%2031%201%20461%20011)
Confirming Inge's confirmation...
http://www.realoem.com/bmw/enUS/showparts?id=0573-USA-09_1989_K569_BMW_K_75_RT_0565,0573_&diagId=13_0519#13311461011 (http://www.realoem.com/bmw/enUS/showparts?id=0573-USA-09_1989_K569_BMW_K_75_RT_0565,0573_&diagId=13_0519#13311461011)
This site, like others similar to it, helped me guarantee I wasn't missing any parts throughout the course of my rebuild, and gave me quantities for parts and part numbers...
http://www.realoem.com/bmw/enUS/select (http://www.realoem.com/bmw/enUS/select)
Best bet is to enter the last 7 digits of your VIN. After doing-so and clicking "search', you can see your Product, Catalog, Series, Model, Market, Type Code and Production Month/Year. After all of that, click "Browse Parts", and you'll be able to search your bike by Main Groups. In your case, it would be the fuel system. Under that, you'd choose the Throttle Housing ASSY/Control Unit. You'll see there's a support column that gives you specifics in some (not all) cases. Like, ID/OD for hoses, and specs for clamps. Clicking on the part numbers will then tell you the part's history, and give you updated part numbers.
Cheers!
Thanks for info. The hose is cheaper on realoem than the other 2 dealers that I checked. I don't see any way to order parts on the realoem site. Is ordering directly possible?
I'm guessing RealOEM doesn't update their prices 4 times a year like the dealers do.
