TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: WHITE91K100RS on March 01, 2018, 05:55:52 PM
Title: Help! Can't Remove aftermarket K&N Oil Filter from K100
Post by: WHITE91K100RS on March 01, 2018, 05:55:52 PM
Hey Brickheads,
Hoping to get some insight from you guys in terms of best approach. I have a 1991 K100 that has an aftermarket K&N brand oil filter with a stripped out nut. As a result, I'm have a hell of a hard time removing this damn oil filter. See filter below:
(https://ibb.co/iKTicc)
I'm trying to get this filter out without having to drop the oil pan on the bike and turn it into a larger project than it needs to be. I saw this video from Chris Harris regarding his clever idea to removing a stuck filter - but I don't think it will work for me due to the large (stripped out....grrr) nut that is on the bottom of the K&N brand filter (see image below)
https://www.youtube.com/watch?v=L9t6cUCwXRg&t=57s (https://www.youtube.com/watch?v=L9t6cUCwXRg&t=57s)
Do any of you guys have any ideas? Any insight from you all would be greatly appreciated. Spring is on the way and I want to get a fresh filter in there  :falldown:
Title: Re: Help! Can't Remove aftermarket K&N Oil Filter from K100
Post by: koapono on March 01, 2018, 07:50:54 PM
try using longer screws to span the gap between K&N filter and BMW filter-wrench. You may have to use larger screws, #10 or so, to handle the additional stress. Seems you have little to lose at this point.
Post by: Chaos on March 01, 2018, 07:58:41 PM
have you tried a large vice grip on the K&N nut, or am I visualizing your problem wrong?  Worst you could do is rip the nut off, then Chris's method ought to work.
Post by: Nailhead on March 01, 2018, 09:04:05 PM
Yeah, that big stripped nut & years in the oilfield say “pipe wrench” to me.
Post by: Laitch on March 01, 2018, 09:26:25 PM
+1
Post by: The Mighty Gryphon on March 01, 2018, 09:43:37 PM
+1    A pipe wrench, vise grips and a big hammer are my end-of-the-world tool kit.
Post by: WHITE91K100RS on March 01, 2018, 09:53:34 PM
Ya, pipe wrench with vice grip was my first plan of attack  but due to how deep the filter is in the oil pan, I can only bite that stripped nut at an angle, not the clean 90 degrees I would like. As a result, I haven't been able to get enough leverage on that sucker to get it to turn.
Feedback here seems consistent, so I'll give it another go tomorrow and Ill report back my with my triumphant victory or dismal failure part deux
Post by: Martin on March 01, 2018, 10:05:27 PM
You could try removing the K&N nut by drilling out the spot welds. Then attach the filter wrench with large screws.
Post by: Laitch on March 01, 2018, 10:17:59 PM
It helps save collective brainpower and time if you tell us everything you've already done—like using a pipe wrench—so we don't need to think of ways to tell you how to do things you've already done. Brain cells don't grow on trees. :giggles
You can't try putting the tip of a shock adjuster wrench into that hole on the nut and remove it that way? No shock wrench?
Then Pull off that filter wrench, go get a cap oil filter wrench of suitable size that has a square opening to fit a ratchet wrench extension, screw the new wrench onto the filter, insert the extension into the filter wrench square opening, attach a ratchet wrench to the extension then remove the filter.
Or something like that there.
Post by: gazman on March 02, 2018, 12:50:30 AM
Sometimes rough as guts is the way to go, hammer a Philips screwdriver through the filter an twist
Post by: alexis291 on March 02, 2018, 06:33:09 AM
Why not take the sump / oil pan off ? You may save time in the long run and it will give you more options to get hold of the filter so you can undo it.
Post by: WHITE91K100RS on March 02, 2018, 01:42:58 PM
Well, I dickered around with a pipe wrench and hammer today, but I wasn't able to get any kind of real bite on this stripped out nut.
-tried pipe wrench with vice
-tried various sized pliers
-tried hammering slightly smaller socket on there
-tried using my air impact ratchet and some force
Yes, I have a shock adjuster wrench, but not sure I'm following your advice here.
Post by: Filmcamera on March 02, 2018, 01:53:51 PM
If there is room to get to it I would try grinding off the K&N nut that is stripped so you can fit a normal oil filter wrench on there and then do the Chris Harris method
Post by: kris on March 02, 2018, 01:59:30 PM
Filmcamera, I was in the same position (except no stripped nut....no nut at all). That filter had been on for 9 years! Dropping the pan was what saved the day for me. In the alternative get a Dremel (or something else small with a cutting wheel) and take the end off the filter. Then I would get some needle-nose Vicegrips and go at 'er! Just twist the shit out of it until it yields....and it will yield! If this doesn't work you can always drop the pan. And don't over-tighten these damn filters going back on. They don't take much more than hand-tight.
Good luck!
Post by: The Mighty Gryphon on March 02, 2018, 02:06:42 PM
A man's gotta do what a man's gotta do...
Post by: WHITE91K100RS on March 02, 2018, 02:14:25 PM
Yes, this is what I was thinking my next step will be. Just try to grind that stripped nut off there and try Chris' approach. Of that doesnt work, then I'll just have to drop the oil pan.
Post by: WHITE91K100RS on March 02, 2018, 02:43:18 PM
Did some googling and found this medieval bastard someone made for their bike when they had same problem. Thinking I might try to fabricate something along these lines for ultra-leverage and bite  :mbird
Post by: alabrew on March 02, 2018, 04:31:28 PM
On my first BMW, an '85 K100RT, I had to lay the bike on it's side, remove the sump pan and, after mangling the filter body, even had to drill holes in the filter plate to get it to release from the threads. Oil that rubber ring and don't over tighten.
Post by: The Mighty Gryphon on March 02, 2018, 04:50:27 PM
Those tools should be called "Filter REMOVAL wrenches".  There is absolutely no need for a wrench to install an oil filter.  Unless, of course, it's on a German motorcylcle where the damn thing is installed where you can't get your fingers on it.
Even then, you just spin it with your fingertips until it stops spinning easily and then give it another 1/4 to 1/2 turn.  If you go further than that, you deserve what you get when you do your next oil change.
Post by: jakgieger on March 02, 2018, 09:13:53 PM
Had a similar problem on my bike :yow .  I attacked it like I do stubborn filters on farm equipment.  Similar to your "medieval" tool, I drive two big screwdrivers through the filter body and then use a lever.  It really helps to have two people :bmwsmile .  The pan also comes off easily...
Post by: BlitzenGruv on March 03, 2018, 01:08:36 AM
What part of finger tight did you not understand?
Post by: Laitch on March 03, 2018, 07:35:11 AM
The fault, dear Blitzen Gruv, is not in ourselves, but in our stars.
Post by: WHITE91K100RS on March 03, 2018, 11:44:57 PM
Well, I was finally able to remove the stubborn oil filter.
Dropped the oil pan to get a better angle, and I bit onto the nut with a large pipe wrench. Gave it a turn with all my might and I ripped the nut right off the filter!
So... with the nut removed, I tried Chris Harris' approach and drilled some holes into my oil filter socket, applied it to the stubborn filter, and drove some sheet metal screws through it. Came out no problem! Eureka. Thanks for all the input all  :2thumbup:
Post by: kris on March 06, 2018, 04:51:22 PM
Can I get an "AMEN!!!" from the crowd, please? :clap:
Post by: Martin on March 06, 2018, 04:58:56 PM
This saga was nearly as long as "Gone with the wind". Please don't let there be a sequel, put a smear of oil on it and do not overtighten it.  :nono
Hallelujiah regards Martin.
Post by: Filmcamera on March 06, 2018, 05:14:02 PM
Well done, I am glad you finally got it off!
Post by: The Mighty Gryphon on March 06, 2018, 05:20:35 PM
+1
For the love of all that's holy, finger tight and only another 1/4 turn.  Another thread like this one will melt my brain.
Post by: Chaos on March 06, 2018, 06:16:43 PM
This brings up an a fantastic way to increase membership to MOTOBRICK.com.  When you're ready to sell torque the crap out of the oil filter with a dry gasket.  Then when the new owner gets hopelessly frustrated he will search us out and be charmed by our whimsical and sage advice.
Post by: pinhead on March 07, 2018, 02:32:03 PM
Is it only the K bike that has this issue with a oil filter in blind hole or do other models of Bmw have similar set up?
Post by: Chaos on March 07, 2018, 06:13:58 PM
the R1100 uses a setup similar to k bikes
Post by: bizzaro on March 08, 2018, 07:08:05 PM
 :popcorm :popcorm   THE END
Post by: Martin on March 08, 2018, 08:00:44 PM
Episode 2 Brick Wars the Forum Strikes Back.
Obi Wan "Luke for Gawdsake do you ever listen, do not never ever use the FORCE on a Brick oil filter. Otherwise you will pass over to the Dark Side and end up buying a Harley"
Luke " Geez Ben I'm really sorry , they tempted me with fingerless gloves, and a promise I could keep on kissing my sister. I couldn't help myself."
Post by: Laitch on March 08, 2018, 08:01:47 PM
 :popcorm
Post by: pinhead on March 08, 2018, 08:17:38 PM
I am working on a tool design/modification for removal of oil filters in blind holes like the Kbikes.  I made/modified one already as a prototype and it works like a charm.  Took out the stuck filter I had in my Bike in 10 seconds.  (See my prior thread on the dilemma I had with a stuck oil filter in my K100).  No hole drilling. no pounding screwdrivers thru oil filter no dropping the oil pan.  Just wanted to see what the market would be for such a tool.
Post by: Martin on March 08, 2018, 09:05:00 PM
I've already got one just get the correct tool for the filters you use, and stick to it. You will only have trouble if you try and use the wrong tool on the wrong filter.
Post by: Veka4 on February 15, 2025, 09:59:44 PM
I'd buy one and give it to the twit that serviced my K100 FOR THE ROADWORTHY THE SELLER HAD TO GET for me to buy and register the bike.   Twit put in The wrong filter that was way to short and had no cap bolt.
Post by: frankenduck on February 15, 2025, 10:38:00 PM
Having dealt with dozens of Ks over the years I've run into my fair share of stubborn oil filters that previous owners had put on way too tight so that the filter wrench just spins on the flutes. What I've found works really well to get a stubborn oil filter out is to put some steel wool around the perimeter of the filter wrench and then pound it onto the oil filter with a hammer or rubber mallet. Works every time with no need to take off the oil sump.
Post by: Veka4 on February 16, 2025, 01:26:46 AM
K& N oil filters KN-163 now have marking on the box "WRENCH-OFF NUT -only for easy removal".
I have found that HF-163. & MAX WCO179NM will seat too deeply to use the BMW hat.   This means that any stiffness will result in a stuck oil filter.
Post by: The Mighty Gryphon on February 16, 2025, 10:26:24 AM
A few months ago I had a similar problem with the proper size cup wrench just spinning on the super tight filter on my new-to-me 2017 Honda Accord which has it's filter tucked away in a cubbyhole under the engine.
After spending most of the afternoon going back and forth to the auto parts store trying to find a cup wrench that would work I put a couple of those nitrile gloves in the wrench that fit the new filter and pushed it onto the old one after washing it off with a shot of brake cleaner and letting it dry.  Then, a mighty tug with an 18" breaker bar...
Spun it right off, easy peasy.  I did have to beat the wrench off of the filter with a block of wood and a hammer, but at least I had it off the engine.
(BTW) Most filters have a pipe thread in them, I think it is 1/2" NPT so a pipe nipple can be screwed into it to hold it in a vise while you get medieval with it.
Post by: pinhead on September 21, 2026, 03:52:56 PM
I have made a special tool by modifying an existing tool and it works!  I have used it on a completely crushed and drilled out oil filter and it took it off.   $40 plus shipping
Post by: Laitch on September 21, 2026, 07:52:15 PM
Post a photo of it, the price and how you want prospective buyers to contact you in the MOTOBRICK Marketplace FS WTB WTT ~ Bikes ~ Parts ~ Gear section.
