MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: The Mighty Gryphon on February 13, 2018, 02:35:53 PM
Title: For Sale...Fuel and Temperature Gauges
Post by: The Mighty Gryphon on February 13, 2018, 02:35:53 PM
Sold...
Starting to clean out the stuff that seems to be breeding in my parts stash when I'm not looking.  First up are additional instruments.  If you have ever thought about adding a fuel and temperature gauge to your RS or RT here are all the parts you need.
Included are both gauges with LED lighting, temperature sending unit, panels for the K100RS, and both of the wiring harnesses.  Everything is used, but in good working condition.
Asking $155 which includes shipping in US and Canada.
Title: Re: For Sale...Fuel and Temperature Gauges
Post by: The Mighty Gryphon on February 13, 2018, 02:54:21 PM
Sold...
Temperarure Gauge #1.  Gauge with cup and nuts,  no wiring or sender.  Has blue LED lighting.
$50 shipped to US or Canada.  Other places I will advise additional postage.
Post by: The Mighty Gryphon on February 13, 2018, 03:09:41 PM
Temperature Gauge #2.  No wiring or sender.  Bezel is beat up but tight.  Green lighting works.
$25 shipped to US or Canada
Post by: alexg on February 18, 2018, 07:58:58 AM
Hello:
Can these be fitted to a 75S, into the factory wire loom? I would be interested if that can be done.
Thanks,
Alex
Post by: The Mighty Gryphon on February 18, 2018, 09:05:33 AM
#1 has been sold.
As far as fitting them to a K75S, yes, it can be done.  Mounting the gauges seems to require separate "Gauge Pods" which don't appear to be available anymore.  An alternative is to cut holes in the fairing with a hole saw to put the gauges in.
The harness has the four pin connector for the gauge harness, but that isn't available outside of the used market anymore either.  Bottom line is that it can be done, but the parts to do it easily are getting scarce.
Post by: The Mighty Gryphon on February 18, 2018, 10:05:20 PM
The two gauges with wiring have been sold.  All that is available now is temperature gauge #2.
Post by: alexg on February 20, 2018, 07:55:04 PM
Mighty:
Can you please give some guidance as to where the 4 pin connector is located in the bike? I cannot find it under the tank.
Thanks,
Alex G
Post by: alexg on February 20, 2018, 08:38:36 PM
Found it, tucked on the RHS of the frame under the tank.
