MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: The Mighty Gryphon on January 26, 2018, 10:21:48 AM
Title: Trailering a Brick
Post by: The Mighty Gryphon on January 26, 2018, 10:21:48 AM
I am going to be moving a K100RS cross country on a trailer next week, about 500 miles.  200 miles of the trip will be on country roads of dubious maintenance history.
Looking at my bike, I'm a bit puzzled as to easily accessible tie down points that don't require removing a bunch of bodywork.  Used to be we just hooked them over the bars on our enduro bikes and wrapped a bunji around the rear wheel and the rail and took off.
A K bike on a flatbed trailer looks like a whole different kettle of fish.
Can anyone post some photos of how you did it?  I know thre are some here, but I don't know how to find them.
Title: Re: Trailering a Brick
Post by: Laitch on January 26, 2018, 11:11:22 AM
The image in this post (http://www.k100-forum.com/t10896-tie-downs#129537) should help, Gryph. He anchored each ratchet strap at two points. I've used a soft loops around each place he used then hooked into the loop with the ratchet strap anchored at one point. The main thing is to limit compressing the suspension at the least possible amount for stabilization.
Post by: The Mighty Gryphon on January 26, 2018, 01:15:32 PM
Exactly what I'm looking for.   Thanks Laitch!  I was a little concerned about how top heavy the bike is, but it appears to not be a problem.
Post by: Martin on January 26, 2018, 03:00:51 PM
Gryph you can also get a strap round the frame in front of the shock and on the opposite side. With side covers removed.
Post by: Skunky on January 26, 2018, 05:11:21 PM
When I moved mine I strapped down on its stand and strapped the back down hard. Did not shift at all. Depends on your trailer whether that's possible.
Post by: Scott_ on January 26, 2018, 08:41:29 PM
When I trailer mine, I tie down the front similar to Drakes picture in the link from Laitch, but as far as the rear, I tie the rear wheel side to side with a slight pull to the rear. This way the bike is fastened firm and the main weight of the bike can float on the suspension--both front and rear.
I'll look and see if I have any pictures.
Post by: Scott_ on January 26, 2018, 09:04:34 PM
Here's a pic of an RS I hauled once.
Post by: K1300S on January 26, 2018, 11:04:28 PM
(http://i397.photobucket.com/albums/pp59/mblytle/k75%20x2/20171014_151607.jpg) (http://s397.photobucket.com/user/mblytle/media/k75%20x2/20171014_151607.jpg.html)
(http://i397.photobucket.com/albums/pp59/mblytle/k75%20x2/20170528_150015.jpg) (http://s397.photobucket.com/user/mblytle/media/k75%20x2/20170528_150015.jpg.html)
(http://i397.photobucket.com/albums/pp59/mblytle/k75%20x2/20170528_150006.jpg) (http://s397.photobucket.com/user/mblytle/media/k75%20x2/20170528_150006.jpg.html)
(http://i397.photobucket.com/albums/pp59/mblytle/K1300s/20170121_102939.jpg) (http://s397.photobucket.com/user/mblytle/media/K1300s/20170121_102939.jpg.html)
Post by: Skunky on January 27, 2018, 12:11:21 AM
Here's another way  :clap:
Post by: The Mighty Gryphon on January 27, 2018, 08:48:59 AM
Thanks for all the great photos.  The trailer I'll be using looks like Scott's so I think I'll copy what he did.  I'm feeling a lot more confident about this trip.
Post by: daveson on January 27, 2018, 11:38:42 PM
i tied mine from the lower triple clamp
i put a rag in the exhaust pipe so dusty air doesnt get sucked in by the vacuum created when the air rushes past
Post by: F14CRAZY on January 28, 2018, 06:54:56 PM
No lie, a few years ago I saw a Chevy Cobalt towing a bike in exactly the same manner on the highway
Post by: Martin on January 28, 2018, 07:07:24 PM
A while ago somebody posted a picture of a device that attached to your tow ball. It took the raised  front wheel of the bike similar to the wheel in the boot, trunk, cargo storage area. You towed running on it's rear wheel. I don't think I would be happy towing that way. :nono
Post by: The Mighty Gryphon on January 28, 2018, 10:25:12 PM
I remember a front wheel rack that attached to a trailer hitch that did the same thing, but only lifting the front wheel 9-10 inches above the road surface.  With the brick, I would remove the rear brake caliper and the drive shaft if I was going to tow that way.
Without a way to run tail, brake and turn signal lights I would think the first cop that sees you will want to talk to you.
Post by: Martin on January 28, 2018, 10:45:26 PM
I doubt very much whether it would be legal in OZ. It might be fine for a light weight bike but definitely not anything heavy.
Post by: Inge K. on January 28, 2018, 11:06:28 PM
LOOK....a double bmW.
Post by: The Mighty Gryphon on January 29, 2018, 08:32:43 AM
A K75 towing an airhead...I love it!
When I rode enduros, there was a guy who used to bring his 175 Penton on top of a fold-out tent camper towed behind a big Hardley.  Took three guys to get his bike up on top of it.
