TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: frankenwing on January 23, 2018, 10:36:11 PM
Title: K75 driveshaft compatibility/interchangeable?
Post by: frankenwing on January 23, 2018, 10:36:11 PM
 I have a 1987 k75, is the driveshaft the same or interchangeable with other models as well? Like can most years of the K75 work with it, can K100 driveshafts go in there? The splines on mine are shot on the final drive end.
Title: Re: K75 driveshaft compatibility/interchangeable?
Post by: Laitch on January 24, 2018, 12:31:47 AM
Your bike should have a 20-tooth drive shaft. Does it? Better count them. You never know when someone has done a retrograde refit. If it does have 20 teeth, any 20-tooth monolever driveshaft should work.
Post by: frankenwing on January 24, 2018, 01:20:30 PM
I just checked: on the final drive end it has 20 teeth. On the U-joint side (connecting to the transmission) it has 16 (if i counted correctly).
If that's still the case, literally any year/model drive shaft will work with mine as long as the final drive end has 20 teeth and trans side is 16?
Post by: Laitch on January 24, 2018, 01:39:58 PM
. . .  on the final drive end it has 20 teeth. On the U-joint side (connecting to the transmission) it has 16 (if i counted correctly).
Count them up again.
Post by: frankenwing on January 24, 2018, 01:42:31 PM
Confirmed. 16 on the gearbox end, 20 on final drive.
Post by: Laitch on January 24, 2018, 06:25:24 PM
It cannot be characterized as literally any. :giggles  It simply needs to be from a monolever bike and mate with a 20-tooth rear drive spline.
Post by: frankenwing on January 24, 2018, 08:27:20 PM
Shoot. Monolever is rear disc brake models right? I have rear drum brake.
Post by: rbm on January 24, 2018, 09:34:40 PM
No, monolever is the drivetrain design used on K-bikes from inception to about 1992.  Paralever was introduced around that time and continued through the classic K-bike series (K1, K100-4V and K1100).  Drum or disk - the same drive shaft can be used.
