MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: rbm on January 14, 2018, 06:58:32 PM
I posted a question about Dieter's K-Kompendium pages going missing and received a reply back from Gerhard Reger, the webmaster for the site, as to the solution to the problem. To access Dieter's pages, use HTTPS (secure SSL link) instead of HTTP (non-secure). So, the URL to access the pages will be https://www.k1100lt.de/files/flybrick/DKTK/index.htm (https://www.k1100lt.de/files/flybrick/DKTK/index.htm)
By the way, if you are not familiar with Deiter's pages, they are a gold mine of K-bike electrical information. There are several pages available, all written in German. The language is not a barrier with Google Translate and a little interpretation. Here are some of the URLs:
Dieter's K-Relais Kompendium https://www.k1100lt.de/files/flybrick/Dkrk/index.htm (http://www.k1100lt.de/files/flybrick/Dkrk/index.htm)
Dieter´s K - Tacho Kompendium https://www.k1100lt.de/files/flybrick/DKTK/index.htm (http://www.k1100lt.de/files/flybrick/DKTK/index.htm)
Detlevs K Tacho Ganganzeigentausch https://www.k1100lt.de/files/flybrick/Tachok100/index.htm (https://www.k1100lt.de/files/flybrick/Tachok100/index.htm)
Weiterreichende Literaturempfehlung https://www.k1100lt.de/files/flybrick/dkjk/literat/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/literat/index.htm)
Jetronik Steuergerät https://www.k1100lt.de/files/flybrick/dkjk/steuerge/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/steuerge/index.htm)
Dokumentation Steuergerät https://www.k1100lt.de/files/flybrick/dkjk/jetronic/j_docu/Jet_testen.htm (https://www.k1100lt.de/files/flybrick/dkjk/jetronic/j_docu/Jet_testen.htm)
Messungen Steuergerät https://www.k1100lt.de/files/flybrick/dkjk/jetronic/j_docu/messungen/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/jetronic/j_docu/messungen/index.htm)
Zündbox https://www.k1100lt.de/files/flybrick/dkjk/zuendox/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/zuendox/index.htm)
Zündgeber https://www.k1100lt.de/files/flybrick/dkjk/zuendgeb/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/zuendgeb/index.htm)
Luftmassenmesser https://www.k1100lt.de/files/flybrick/dkjk/luftmass/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/luftmass/index.htm)
Stomläufe K75 / K100 2V https://www.k1100lt.de/files/flybrick/dkjk/stromlau/index.htm (https://www.k1100lt.de/files/flybrick/dkjk/stromlau/index.htm)
Danke Rob, das ist wunderbar sehr geschätzt.
Grüße Martin.
