TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: burntstick on December 05, 2017, 05:47:14 PM
Title: k75 valve maintenance
Post by: burntstick on December 05, 2017, 05:47:14 PM
91 k75rt 140000kms alberta,can
Previously loved bike with unknown valve maintenance. Should valve clearance be checked? Are burnt valves common on bike? How many valves per cylinder do i own ?
Thanks heaps!
Title: Re: k75 valve maintenance
Post by: Chaos on December 05, 2017, 06:06:39 PM
Valves are very easy to check and you should do it pronto.  Tight valves will burn.  The problem is these bikes will go long periods not needing an adjustment so people forget about checking them.  All K75's are 2 valve.
Post by: burntstick on December 05, 2017, 07:09:49 PM
Thanks merry Christmas!
Post by: stokester on December 05, 2017, 08:11:38 PM
Yes, do it.   I had checked my right after I got my 40k K75 finding them within specs.  Fast forward 30k and I checked them again to find the exhaust valves on #1 and #2 with almost no clearance to the cam.  Searching on this site I found that cold-bloodedness or slow warm-up is a sign of this as the valves do not spend enough time on the seat to transfer heat.
The tools to change them are available from Ken Lively which is what I use and shims are used on some Japanese bikes as well.
Post by: burntstick on December 05, 2017, 08:15:25 PM
Thanks nick
Post by: The Mighty Gryphon on December 05, 2017, 11:37:14 PM
You don't need any special tools to check the valves, only to change the shims.  Pop the valve cover and check them.  All you need is a set of feeler gauges.  Do it as part of a spark plug change.  The plugs are easier to change with the cover removed, and the engine is easier to turn with the plugs out.
You should be able to check them and change the plugs in under an hour.  Beyond the the plug wrench, allen wrench and a wrench to turn the cam, a pan to catch the oil that comes out when the valve cover is removed.
Post by: burntstick on December 06, 2017, 12:30:29 AM
I appreciate the tips m.g.
Post by: MCRyder on December 12, 2017, 09:46:35 PM
I did a valve check on my RT recently.  It took more time to remove fairing panels then to do the check.  I used this vid as a tutorial, very helpful.  Hope you don't have sensitive ears, Chris's language gets a bit rough  :yes
https://youtu.be/bFkPnLVkxWQ (https://youtu.be/bFkPnLVkxWQ)
Post by: TX brick on December 13, 2017, 05:41:05 AM
Contrary to the remarks on the above video, my K75 valves have needed adjustment. A reduced hot idle speed is an indication of tight exhaust valves.
Post by: Scott_ on December 13, 2017, 06:48:08 AM
Another suggestion is to check the valves BEFORE you remove the spark plugs.... reason being, the process of removing the spark plug has the potential of breaking loose any carbon deposits near the plug and that then creates the potential situation of the loose carbon getting stuck in an exhaust valve opening and skewing your results.
Chances of this happening are low, but apparently it has happened with some as it is suggested by BMW in the service manuals.
Post by: burntstick on December 13, 2017, 12:53:36 PM
Good one ! Thks
Post by: technostructural on December 18, 2017, 04:20:13 PM
I checked mine in June of this year, and I found them all to be a tad loose. I took Chris Harris' advice and left them the F&*K alone.
Post by: blackie1 on December 18, 2017, 11:34:20 PM
in a post above The mighty gryphon says  "Pop the valve cover and check them."
do you need to replace the valve cover gasket every time you remove the valve cover or only if it is torn or perished etc
Post by: Martin on December 18, 2017, 11:54:39 PM
Replace only if damaged, a light smear of Three Bond 1104 liquid rubber gasket will reseal it. Allow time for it to set.
Post by: blackie1 on December 19, 2017, 02:01:49 AM
thanks martin
