TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Billk on December 03, 2017, 07:56:21 PM
Title: Rear Brake substitute
Post by: Billk on December 03, 2017, 07:56:21 PM
I have a 1995 K75 with ABS brakes. I would like to substitute my rear brake ABS caliper with one from a 1994 non-ABS caliper. I would be running the 1994 non-ABS brake line and bypassing the ABS unit. What problems if any would I run into?
I’m also looking for a dust boot for the brake caliper piston. Any ideas would be appreciated. thank you
Title: Re: Rear Brake substitute
Post by: Martin on December 04, 2017, 12:28:04 AM
Bill I looked up the parts book on Motor Works UK and there is no difference between ABS and non ABS calipers.
Post by: The Mighty Gryphon on December 04, 2017, 09:03:19 AM
I stripped the ABS off of Moby Brick and rode 20,000 miles with the original calipers.  No problem.
Post by: koapono on December 09, 2017, 08:38:08 AM
I removed entire ABS system with exception of calipers and master cylinders from my 94 LT.
no issues.
