MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: Paul Hosticka on November 10, 2017, 02:18:59 PM
Title: WTB Trip odometer BMW#6211230175 1992 K75RT
Post by: Paul Hosticka on November 10, 2017, 02:18:59 PM
Want new, used but working, or core. Need one black tumbler
Title: Re: WTB Trip odometer BMW#6211230175 1992 K75RT
Post by: mtwhickory on November 18, 2017, 01:17:10 AM
If yours isn't working I can tell you how to fix it.
Post by: Paul Hosticka on November 18, 2017, 11:42:22 AM
Found a core cluster with working trip and am installing today. I hate stuff that doesn't work. Anyone know about the so called self canceling turn signal circuit, mine has never worked? If it is in the cluster maybe I can swap it out.
Post by: Laitch on November 18, 2017, 01:59:02 PM
Although the post in this link (http://www.k100-forum.com/t3221-self-cancel-indicators-turn-signals#30328) doesn't answer whether the cluster is involved, it does show that a correctable defect in the switch assembly can cause failure to function. The entire thread could be of interest to you.
Post by: Inge K. on November 18, 2017, 07:45:43 PM
The path for the pulse signal is divided between the speedo itself and the turn signal relay after the
preamplifier inside the cluster.
It's a blue/green wire between the cluster and relay, check the connections and if you have signal
using a analogue meter set to milliamps.
