TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: beemuker on November 10, 2017, 01:12:05 PM
Title: will a 1992 BMW K75 RT S790 seat fit a "94 K75s?
Post by: beemuker on November 10, 2017, 01:12:05 PM
There is one on ebay that matches "old yeller" . it has yellow piping. I think they are all the same, except the "low", but I could be wrong.
https://www.ebay.com/itm/1992-BMW-K75-RT-S790-Corbin-seat-saddle-2-NICE/292298471881?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3D397ada803ea74913bb26b08b8d53a0b8%26pid%3D100290%26rk%3D3%26rkt%3D4%26sd%3D132378722913&_trksid=p2060778.c100290.m3507
Title: Re: will a 1992 BMW K75 RT S790 seat fit a "94 K75s?
Post by: Martin on November 10, 2017, 02:50:18 PM
Seats are interchangeable if the hinges are compatible, or they and pertinent to that seat. OEM seats will interchange between relevant heights, high seat for high seat, low seat for low seat. this excludes the very early ones with the built in grab handle. Some aftermarket fibreglass seats used OEM hinges, but I'm not sure if they all did.
Post by: rbm on November 10, 2017, 04:23:18 PM
Correct Martin. Seat design changed with the MY1985.  After that, seats are interchangeable through the K1100 as you describe.
Post by: beemuker on November 10, 2017, 05:51:51 PM
Called corbin, the rep said you have to use the OEM hinges, so I should be good to go with it.
