TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: PaulP on November 02, 2017, 06:29:38 PM
Morning / Afternoon / Evening.
I'm going to be indulging in a little jiggery-pokery with the exhaust system on my K100.
Are there any issues regarding back pressure (either too much or too little) which might cause a problem if the engine>silencer distances are altered?
Is the K. engine particularly susceptible to such alterations, or is it robust enough to laugh in the face of untuned pressure waves?
Cheers
Various exhaust have been tried on Bricks. And from the reports that I have seen there is nothing to be gained performance wise. The only advantages are weight reduction and noisier if that's an advantage.
Thanks for that.
I seek no performance or noise gains, it's just that I want to reposition the exhaust for aesthetic purposes and get rid of the fairly ugly (IMHO) silencer.
In order to achieve this I need to add some length to the manifold pipes, and I was concerned it may have an adverse effect on valves/stems and such like.
I have run a Luftmeister and now a MAC pipe for decades with no ill effects. I think the FI brain compensates for backpressure up to a point. When the baffle blew out of the luftmeister and it became an open cone the engine was not a happy camper.
If that is the case I would try and find one of the made for replacement ones. Try looking for a Luftmeister, MAC or Staintune, that way you know that the state of tune will not be adversely effected.
Thank you both.
I've a couple of nice Pan European stainless silencers which I intend to 'make fit', but as mentioned I'll also need to add a few inches to the manifold pipes to get 'em to where I want 'em.
Satisfied that I can make a modest change without the lump exploding into a fiery ball of shrapnel, I shall crack on....
Never knew that MAC made a K system. Just looked it up at Dime City Cycles. They say that carburetor rejetting may be necessary. So factor that in to your budget.
Yes, that would be difficult on a K :hehehe
No Chaos, it means that in order to run the exhaust you must fit carbies. :hehehe
