TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: Blunderbust on October 22, 2017, 04:46:45 PM
(https://www.motobrick.com/[imghttps://www.motobrick.com/gallery/0/4907-211017175624-7682377.jpeg)
Hi all, as I stated in my intro I have acquired an 1984 K100 in a bit of a sorry state. I collected it in July but due to being on a bike tour of Europe for a couple of weeks and having a few bike meets to attend I have only really started doing anything with it over the last couple of weeks. Here is a pic of what the old girl looks like at the time of arrival. I have decided that the most economical way of getting it back on the road is to turn her into a street scrambler with a black and yellow paint job, hence the name Wasp. Watch this space.
(https://www.motobrick.com/gallery/0/4907-211017175624-7682377.jpeg)
here are a couple of more pics before I got started
(https://www.motobrick.com/gallery/0/4907-211017175657-772108.jpeg)
(https://www.motobrick.com/gallery/0/4907-211017175711-7732059.jpeg)
I know I have my work cut out but I do enjoy a challenge even if it is going to cost me :yow .
(https://www.motobrick.com/gallery/0/4907-211017175624-7682378.jpeg)
What in the world are people thinking?
Look forward to watching you turn this into a motorcycle.
In Italian that would bee Vespa ...
Good job I am not Italian then ain't it.
Hi blundering, welcome aboard, the bike looks reasonably clean and someone spent time stripping the tank. Hope you have most of the missing bits. Good luck with your project. Do you know if she was a runner.
The tank has been half heartedly cleaned if you were able to see it you could see that there are 2 x dents and the edges and badge recess are still in a mess with multi coats of paint. I fear that he may have gouged it and won't know if there are any leaks until I get a chance to check it. I got a few bolts and bits and pieces with the bike and I am still getting others as time goes on. I suppose I can liken it to having bought the bike in installments but in reverse, LOL. I have been assured that before he got the bike it was a runner and I do know the owner before him who has confirmed this. Unfortunately I was not given the keys, tank cap, seat, and numerous other items indeed the list grows longer every time I start to do things on it. To be honest it was my own fault and was assured that all the bits I needed were available in a box which I was given with the bike, being that he was a friend I stupidly did not look in great detail. Lesson learned never buy from a friend.
I have got new replacement brake disks/pads and various other bits which has cost me a small fortune and I am determined to get the bike back on the road buy end April, beginning May next year :bmwsmile .
Over the last couple of weeks I have stripped the wheels, 5 x coats which consisted of varnish, gold paint, varnish, silver paint and a very heavy self etching undercoat.
(https://www.motobrick.com/gallery/0/4907-221017160906.jpeg)
First coat above came off in lumps until it came to getting into the edges and hard to reach bits
(https://www.motobrick.com/gallery/0/4907-221017161147.jpeg)
Paint stripper doing its bit but it had to be done 5 times to remove each coat.
(https://www.motobrick.com/gallery/0/4907-221017162155-777900.jpeg)
(https://www.motobrick.com/gallery/0/4907-221017162024.jpeg)
Wheels done and tyres fitted so that I can get the wheels on the bike and work out my seat hight, before the frame is removed ready to start welding.
...Lesson learned never buy from a friend.
Have you tried teaching the seller to never screw a friend? I would be after them non-stop for the missing parts or some compensation from the selling price.
[/quote
I can understand where you are coming from, but as you could not know my friend or his circumstances the suggestion of teaching him anything is not and never would be in my thoughts and would never ever happen. He has an illness that does mess with his thinking and actions. Take it from me he does not intentionally go out to screw anyone.
Hi Blunderbust, Wheels look great. What tyres are they. :clap:
Thanks Skunky, although I have to admit they are not staying silver, once I stripped them they started to show a fair bit of damage and will need to be filled and sanded before I paint them. The tyres are Heidenau K60's, they have a good look and surprisingly get a good review for on road use as well.
What size is the front it looks slightly oversized
The front is a 110/80 - 18.
Spent a bit of time this weekend and fitted the new exhaust and shock so that I could go firm and weld the frame addition to fit the seat.
(https://www.motobrick.com/gallery/0/4907-291017170643.jpeg)
Looking good, well I think so, LOL.
(https://www.motobrick.com/gallery/0/4907-291017170534.jpeg)
I stripped the final drive and the shaft so that I could check clean and re greased the splines, I was pleasantly surprised with the condition of the splines considering the mileage the bike had done. I did notes that the rubber boot for the clutch was needing replaced and the gear indicator switch was deteriorating a bit. It seems that the plastic is breaking away, I will try to seal it with putty glue and check if it is still working if not it will need replacing as well. Next I need to knock up some sort of bracket for fitting the front mudguard.
Swing arm angle looks off. How long is that shock compared to stock?
The shock is 30mm longer than stock, supplied by BSK speedworks. That being said the rear wheel is lifted of the bench by the centre lift unit.
Oh right I didn't notice the blue lift.
Sorry I have not been posting about my build it is just that due to other commitments and projects it has taken me a lot longer than I thought. I have been working on the bike but it has been spread over the last 2 . 5 years. I will update on how I have been doing soon.
(http://www.motobrick.com/gallery/3/4907-180420111411-3029530.jpeg)
Engine out cleaning in process.
(http://www.motobrick.com/gallery/3/4907-180420111141-30221415.jpeg)
Other bits and pieces stripped cleaned and tested
(http://www.motobrick.com/gallery/3/4907-180420111141-30221448.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420111305-30251659.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420111200-3024776.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420111020-3020983.jpeg)
Decided to experiment with new switches so that I could get other controls and use the M- Unit.
(http://www.motobrick.com/gallery/3/4907-180420111005-30161182.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420111013-30181847.jpeg)
Now looking at the MAF and air filter options. The new Spal Fan can also be seen in place. This option gives a bit more room in behind where the original fan stem was.
(http://www.motobrick.com/gallery/3/4907-180420110938-30141778.jpeg)
Painted the tank, just a bit more rubbing down before polishing.
(http://www.motobrick.com/gallery/3/4907-180420110932-30131298.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420110919-30111860.jpeg)
Experimenting with a nose plate. The work continue's.
this gonna be hawt... bees knees knocking in anticapation...
That's coming along nicely. 112350 Are you going to do the CT70 after this?
Yes that is next on the list. I also did a Moto Guzzi half way through this one, it all depends on what I can get at a reasonable price.
fuck mang, that is sexy. Looks very nice compared to a lot of people hoping for a similar look. I like that seat riser that makes it line up with the tank well.
Throughout my time working on the bike I have made some changes which include lowering the seat height slightly from my original plan (was too high initially). I did not like my first end can so bought an other which looks much better (IMO). Decided that using the original hand controls was looking a bit ugly and also I was having problems getting them set up so opted for a complete change. Due to this I also decided to sell on my BEP 3 and move to the M-Unit which makes the wiring much easier. Had my seat recovered with a yellow piping and beefed up the padding (Done by a friend). At first I covered the air box with carbon look sheeting but could not resist the smaller weld up job that I saw on the internet.
(http://www.motobrick.com/gallery/3/4907-180420110924-30122279.jpeg)
(http://www.motobrick.com/gallery/3/4907-180420111320-3026435.jpeg)
I find that the alternative controls gives the bike a cleaner more minimalist look. I am working on the bike again today and hopefully I will get the front light and mud guard in place. Wait out!!!!
Thank you Johnny 112350.
Looking good. I guess you're getting 'Covid time'. I'm looking forward to the finished bike. I'd like to see the weld up air box.
Skunky, when I finish work today I will take a closer pic of the air box.
You and me supporting the economy 112350
Did a couple of hours this evening, fitted front light and mud guard. Placed on the seat, side covers and the tank just to have a look at how it is fitting together.
(http://www.motobrick.com/gallery/3/4907-190420164245-30692179.jpeg)
(http://www.motobrick.com/gallery/3/4907-190420164243-30671837.jpeg)
(http://www.motobrick.com/gallery/3/4907-190420164239-30651892.jpeg)
(http://www.motobrick.com/gallery/3/4907-190420164227-30621082.jpeg)
Still lots to do including fit foot pegs, bleed rear brake, make a couple of brackets to secure the MAF and the overflow bottle for the radiator. Finish the wiring, finish rubbing down the paint work. Fill all the oils and radiator, get it to run. Give it a good wash and polish ready for when I can eventually get it MOT'd and on the road. Wait out.
