TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Deepnoizer on October 13, 2017, 08:06:40 AM
I'm working on stripped down (93) K1100 and I'm in process of cleaning up wiring a bit. I found tucked away and taped two relays by front fork I got no idea what they are.
Any idea?
(https://i.imgur.com/3K98C4t.jpg)
(https://imgur.com/3K98C4t)
I'm guessing they're headlight relays. If you pull them out, I'll bet that your headlight won't work. They are there to keep the headlight current from burning up the dimmer switch on the left handlebar.
Thank you I will test that later.
The relays is for the windscreen lifter motor.
+1
I have them on both my LT's.
So they can safely go if my windshield is gone I assume ?
What do believe might happen if you remove them?
