TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: DRxBMW on September 18, 2011, 06:51:43 PM
Title: pegged throttle syndrome
Post by: DRxBMW on September 18, 2011, 06:51:43 PM
funky throttle issue this afternoon, almost like the cable moved/lost partial tension. It's NOT sticky per say just mega slack in the closed position. WFO, it's pegged in about a 3/8 turn instead of full on. Only works in the halfway position,strange. NOT really sure if it's even fixable other than a new R&R.
It is possible the cog, grip tooth ring or throttle chain are compromised ? Last time around I had the assembly apart for inspection & lubrication, chain & cogs seemed OK ? NOT like there massive forces at work too affect anyway, ______ dunno ?
Where should I go next ? Hoping, "an engineer's night-mere word", that it's a simple adjustment. For the record, this K 75 has had a semi hard throttle pull since new, dealer proclaimed it was OK when I complained.
On the brighter side, I was able to end the day without roadside wrenching or total failure. Weird, 70 mph was all I could do, read pegged throttle syndrome sucks.
Title: Re: pegged throttle syndrome
Post by: frankenduck on September 18, 2011, 08:07:46 PM
Why not take the screw out next to the MC and take a peek?
Post by: DRxBMW on September 18, 2011, 08:25:54 PM
Plan is to inspect A to Z,report back. BTDT, with idle/throttle advance/cold start adjustment,enough said.
I've NEVER wrenched on a new throttle cable before, stay tuned. Different lengths for the style of handlebars,badge is the C model.
God, I miss my GS, being outfitted with Jesse bags at CSM Motosports, Middleburg, Pa currently.
Post by: frankenduck on September 18, 2011, 09:11:03 PM
32731457376 or 32731457016 should work for C or S bars.
Post by: DRxBMW on September 19, 2011, 03:22:30 PM
Problem solved, somehow the cog & throttle tube walked from there reference/index marks _________.
Cover screw was slightly loose. Guessing that the cover anchors the cog/cam right ?
Post by: frankenduck on September 19, 2011, 06:52:28 PM
Yes, if you look at the bottom of that plate you'll see a thing that sticks out that fits into a groove on the throttle tube and holds it in place.
